Author Topic: Corsa air con question  (Read 1743 times)
Big_Al
« on: 14 July 2011, 16:55:26 »
hi guys,     got SWMBO a W reg 1.2 ecotech corsa to run around in . Nice little motor , she loves it anyway.
It has AC fitted but it does not seem to work.  started having a look at what it could be & when you pull the dash switch to put the AC on the "Frost" sign lights up but the compessor is not engaging at all . Had a look at the electrical connectors & all seem OK. checked 2 fuses that I think are for AC & both OK.
Any ideas where to start ?  TIA         AL :y :y :y
Re: Corsa air con question
« Reply #1 on: 14 July 2011, 16:57:54 »
Need to get the gas pressures checked.
I have seen a couple of issues:
1) Failure of the main hose that runs along the left side of the engine bay
2) Condenser failure
3) O ring failure around the expansion valve on the bulk head.
Big_Al
« Reply #2 on: 14 July 2011, 18:00:23 »
thanks for the reply,
So would it be  that if any one  of these faults are there -  this would prevent the compessor from engaging ?  :-/ :-/ :-/
« Reply #3 on: 14 July 2011, 18:14:08 »
Mark means that any one of those potential faults will result in low gas pressure, which in turns prevents the compressor from engaging.  :y  :y
Big_Al
« Reply #4 on: 14 July 2011, 18:35:35 »
Thanks Mark, Thanks Andy , will look into getting pressures checked.   :y :y
Matchless
  • Nottingham
    • A white van
« Reply #5 on: 14 July 2011, 18:40:27 »
Also look for any cables or pipes rubbing against the alloy a/c pipes...can wear a hole in them very quickly.
Big_Al
« Reply #6 on: 14 July 2011, 18:47:18 »
Will do  -  thanks :y
the alarming man
  • medway kent
    • disco V8
« Reply #7 on: 14 July 2011, 23:33:21 »
would the compressor engage if the system was in need of a regas???? :y
« Reply #8 on: 14 July 2011, 23:39:57 »
No. The low pressure switch will stop it from doing so.  :y
