Author Topic: Self levelling  (Read 3697 times)
Tonka.
  • Lincoln, Lincolnshire
    • 2000 2.5 CDX
Self levelling
« on: 13 July 2011, 17:38:31 »
Just investigating a possibility for improving the ride whilst towing.
Is it possible to fit self levelling suspension to my CDX?
If it is possible, what is involved, what parts would I need and how much should the parts cost from an OOF breaker??
Just curious.......... ::)
« Last Edit: 13 July 2011, 17:39:08 by Tonkapaj »
The happiest people don't have the best of everything,
they just make the best of everything they have.
Varche
  • middle of Andalucia
    • Golf Estate
Re: Self levelling
« Reply #1 on: 13 July 2011, 19:58:52 »
My personal view would be that it is nothing but hassle. You would be better off buying some Bilstein B4's and some spring assisters.
If the wiring is present in your loom you would need the sensors, front to rear air pipes, the pump which fits up under the front wing and a pair of good working s/l shockers , Oh and the softer rear springs without broken bits.
The shockers probably would need buying new and even on TC are a lot of dosh (£160 at a guess for a pair).
having said that I have everything you need apart from the shockers on my elite I am breaking. It all works except the shockers which are shot. Make me an offer and I will package it all up and post it to England on payment of a small Paypal deposit.     :y
Tonka.
    • 2000 2.5 CDX
Re: Self levelling
« Reply #2 on: 13 July 2011, 20:05:58 »
I think I will stick with the spring assisters. once i have bought them off a forum member  :y :y
Thanks for your advice Varche  :y
Re: Self levelling
« Reply #3 on: 14 July 2011, 05:34:50 »
Depends if the relevant loom connectors are present I guess. But I have a feeling elite looms are differant?
Otherwise it's plug and play. Will work with any springs, as plod prove.
As dampers they aren't brilliant. Maybe the Monroe air assist dampers would be better on non elite cars?
Martin_1962
Re: Self levelling
« Reply #4 on: 14 July 2011, 22:06:52 »
Seem OK to me
Wonder if they wound connect to a SL system
Re: Self levelling
« Reply #5 on: 14 July 2011, 22:48:10 »
Seem OK to me
If they are better dampers it would be worth a go for Elite owners I guess.
Does anyone know if the sl loom and connectors are present on gls, cd, cdx, mv6? Guessing not...?
Martin_1962
Re: Self levelling
« Reply #6 on: 15 July 2011, 09:55:14 »
Seem OK to me
If they are pump and stuff may be wanted
Re: Self levelling
« Reply #7 on: 15 July 2011, 17:55:50 »
Seem OK to me
... And some ingenuity  :) guessing the key will be connecting omega air line to Monroe shock body.
« Last Edit: 15 July 2011, 17:57:03 by chrisgixer »
Varche
    • Golf Estate
Re: Self levelling
« Reply #8 on: 15 July 2011, 19:26:42 »
Seem OK to me
Chris, I don't think the Monroes work that way. My understanding is that the shocks have a schraeder valve and you can pump them up with a standard tyre airline for when you are towing or carrying a boot load of stuff. For normal use you let some air out of the valve on each side. They don't interface with the Omega s/l air pipes at all.
Re: Self levelling
« Reply #9 on: 15 July 2011, 20:08:08 »
Seem OK to me
Understood. The thinking is the Monroes are better dampers. So it's an attempt on the best of both worlds. Automatic Monroes with omega system. I have no idea how they work, never laid eyes on them.
We are in Martins world, as he has Monroes on his.  :-/
Re: Self levelling
« Reply #10 on: 15 July 2011, 21:11:43 »
I have a vague recollection of someone managing to find aftermarket shocks that connect to the Vx Airlines :-/ :-/
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
Re: Self levelling
« Reply #11 on: 15 July 2011, 21:54:57 »
I've got monroes on my elite. The airlines clip on as normal, or there is a hose and pressure gauge allowing you to control pressure manually
TC and BnQ Trade holder.
Re: Self levelling
« Reply #12 on: 15 July 2011, 21:58:12 »
And do they rise/fall properly if you move the sensor arm?
geoffr70
  • Sunderland
  • Boobies
Re: Self levelling
« Reply #13 on: 15 July 2011, 22:54:14 »
Of course
Re: Self levelling
« Reply #14 on: 16 July 2011, 09:16:55 »
And is the ride better than standard Vx ones?
