Author Topic: Inlet manifold  (Read 1802 times)
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Inlet manifold
« on: 18 July 2011, 08:42:14 »
Morning all,
After having JamesV6CDX work his magic on my LPG yesterday, he's suggested re-routing the pipework and injectors to make it more efficient.
He recommends a replacement inlet manifold and plenum.
Question: Is it best to stick with a direct 3.0 replacement manifold/plenum or get one off a 3.2 (if it's the same?)
He also said about getting the new manifold drilled for the LPG injectors, is there anyone that is able to do this please?
This can't be done just yet due to finances (still out of work) and having an knee op in 3 weeks, so looking at costs so I can save up fot it, along with cambelt/cam covers/water pump & powersteering pump  :'(
Thanks for any advice  :y
« Last Edit: 18 July 2011, 08:42:44 by blackviper90210 »
AKA - Mr Bracket
Re: Inlet manifold
« Reply #1 on: 18 July 2011, 08:56:39 »
Morning all,
Got a 3.0ltr inlet with injectors for £25 posted if you need one :)
Re: Inlet manifold
« Reply #2 on: 18 July 2011, 09:08:26 »
You need the 3.0 plenum, it's different. No icv or egr inlet on a 3.2.  ;)
blackviper90210
Re: Inlet manifold
« Reply #3 on: 18 July 2011, 09:14:12 »
Cheers for that Chris  :y
AKA - Mr Bracket
blackviper90210
Re: Inlet manifold
« Reply #4 on: 18 July 2011, 09:16:50 »
Morning all,
Hi RobG,
I'm going on what James explained:  are the injectors low down on the manifold and angled downwards?
He said that it's more efficient rather than pointing 90deg to the airflow.
Cheers, Dave
AKA - Mr Bracket
Re: Inlet manifold
« Reply #5 on: 18 July 2011, 09:27:47 »
I suspect RobG's inlet just has the petrol injectors, not drilled for LPG  :-/
Re: Inlet manifold
« Reply #6 on: 18 July 2011, 09:43:25 »
Correct
blackviper90210
Re: Inlet manifold
« Reply #7 on: 18 July 2011, 10:22:26 »
Apologies Rob, mis understood your offer!!  ::)
AKA - Mr Bracket
