Author Topic: I hope the stag wiring diagram is correct!!  (Read 4712 times)
Re: I hope the stag wiring diagram is correct!!
« Reply #15 on: 20 July 2011, 23:22:53 »
There is a wiring diagram complete with the pinouts for the ECU itself on the AC web site. You can buzz the connections right back to the ECU pins to double check it and then realise the misfire is down to a squashed pipe.
In my experience, the colour coding in the loom is correct, though.
Ken T
  • Stockport
« Reply #16 on: 20 July 2011, 23:25:41 »
Not bad....
However that's more than I paid for the new car, and when you add in Pinky's potential bill ( he now charges for  bacon butties  :'( ) its heading for twice the cost of the car.
Ken
Tip for buying a Mig V6. Wait until the school holidays are due, and you will see lots of cars with 80000 miles, cause the garage says it needs the cam belt change which costs a lot, so people quickly trade them in for what ever they can get.
That may be the case, but if you plan to do more thank 10k in your ownership of the car it will more than pay for itself in the savings ;)
I think my current 30K/PA will pay off quite quickly  :-X
Ken
« Reply #17 on: 21 July 2011, 01:07:28 »
:-[  :-X  ::)
« Reply #18 on: 21 July 2011, 02:20:03 »
you mean trust the wiring colours?
Yep. There is method to them IIRC, but I haven't got a wiring diagram to hand.
Which reminds me... I must modify the loom for johnnycboy's conversion ::) ::)
[/highlight]
Dont forget your raincoat if your doing it this weekend. ;) ::)
This weekend :o. Where/Why/When :o
Afaik theres an LPG install planned at JCB,s this weekend. :-/
« Reply #19 on: 21 July 2011, 10:17:17 »
[/highlight]
There is indeed... We thought you were busy though TB? ::)
Forecast doesn't actually seem too bad though. It's only a front end and pipework fitting, plus all the wiring, as he's already got the tank in :y :y
« Reply #20 on: 21 July 2011, 11:29:00 »
Might pop own and take the piss say hello between shifts, if its dry and I can drag myself out of bed. :)
« Reply #21 on: 21 July 2011, 12:24:18 »
I will also be completing my install this weekend, only, I'm a billy no mates, so it's a single handed job  :-[
« Reply #22 on: 21 July 2011, 12:31:41 »
The stag installation diagram shows a wire being cut on each petrol injector?
Presumably this doesn't have to be physically cut - as the piggyback loom does this job for you?
« Reply #23 on: 21 July 2011, 13:30:20 »
Yep... Piggyback does all that :y :y
« Reply #24 on: 21 July 2011, 13:36:02 »
Cheers, LD :y :y
« Reply #25 on: 21 July 2011, 19:07:03 »
Diag is proven correct several times. Kev checked it for me a couple months ago. ;)
« Reply #26 on: 21 July 2011, 19:08:20 »
Wiring diag is bang on. If it wasn't, loads of us would be up a smelly inlet, oarless.
« Reply #27 on: 21 July 2011, 19:16:06 »
Indeed... Only mistake I have ever found (once) was that the little clips were switched and one was missing once, but the actual coloured wiring was spot on :y :y
Another LPG loom modified today ;) ;)
