Pages: [1] 2 3  All   Go Down
Author Topic: licence for towing caravan  (Read 5470 times)
serek
  • huntingdon
    • 3.2 mv6
« on: 08 August 2011, 12:20:47 »
as above what sort of car licence I need for towing caravan ??
I pass my test on 1999 and have got B on it
Re: licence for towing caravan
« Reply #1 on: 08 August 2011, 12:26:46 »
Depends on the size of the caravan you want to tow. As long as the gross train weight is less than 3500kg you can tow the caravan on your licence. But as I passed my test 30 odd years ago I've never really studied it all in detail.  :-/
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #2 on: 08 August 2011, 12:34:49 »
I thought the trailer had to be no more than 750kg on a B?  Above which I thought you needed B+E.   I could be wrong though  :-/
« Reply #3 on: 08 August 2011, 12:36:38 »
Wait till Nige gets back from holiday. He knows all about MPTW, kerb weights, gross weights etc etc.
Your answer is far too simplistic though.  ;) ;)
« Reply #4 on: 08 August 2011, 12:50:27 »
http://www.direct.gov.uk/en/Motoring/DriverLicensing/CaravansTrailersCommercialVehicles/DG_4022564
http://www.direct.gov.uk/en/Motoring/DriverLicensing/WhatCanYouDriveAndYourObligations/DG_4022547
Some info here, but it's all very confusing what you can & can't tow. Also it's not the actual weight of the trailer that counts, it's the Max Authorised Weight that counts. So you could have the rediculous situation that if you towed an empty car trailer weighing 1 ton but a MAM of 2.5 ton and then towed it with a car with a kerb weight of 2 ton you're over the 3.5 ton limit because of what the trailer could have carried. To me, that's like prosecuting a driver of speeding because his car could do 150 mph  :-? :-? :-?
Gaffers
« Reply #5 on: 08 August 2011, 12:50:40 »
a 2 minute search found the answer:
http://www.direct.gov.uk/en/Motoring/DriverLicensing/CaravansTrailersCommercialVehicles/DG_10013073
We were both half correct Andy  :y
Edit: beat me to it  >:( ;D
« Last Edit: 08 August 2011, 12:51:14 by mrgaffney »
« Reply #6 on: 08 August 2011, 12:53:48 »
Yep. If you can understand it, you can bet it's not the definitive DVLA advice. ;)
Category B: Vehicles up to 3.5 tonnes MAM and with up to eight passenger seats
Category B vehicles may be coupled with a trailer up to 750kgs MAM (allowing a combined weight up to 4.25 tonnes MAM) or a trailer over 750kgs MAM provided the MAM of the trailer does not exceed the unladen weight of the towing vehicle, and the combination does not exceed 3.5 tonnes MAM.
Category B+E: Vehicles up to 3.5 tonnes MAM towing trailers over 750kgs MAM
Category B+E allows vehicles up to 3.5 tonnes MAM to be combined with trailers in excess of 750kgs MAM. In order to gain this entitlement new category B licence holders have to pass a further practical test for category B+E. There is no category B+E theory test. For driver licensing purposes there are no vehicle/trailer weight ratio limits for category B+E.
Gaffers
« Reply #7 on: 08 August 2011, 12:53:58 »
If his caravan is less than 750 kerb weight and the MAM does not exceed the vehicle MAM or 3500kg (which on an Omega it wont) then he can do so on his B.  If the Caravan KW is higher than 750kg but the combined MAM of both vehicle and caravan do not exceed 3500kg then he needs B+E.  If the Combined MAM goes over 3500kg then he is getting into C1 and C1+E territory  :y
Gaffers
« Reply #8 on: 08 August 2011, 12:56:17 »
The first example they give on that page contradicts the preceeding paragraph.  Oh the DVLA, unless c................
« Reply #9 on: 08 August 2011, 13:03:11 »
See.. Even they can't understand the drivel they generate. ;D
Drivel which results in drivers choosing lighter tow cars to stay clear of the 3.5 tonne limit.
serek
  • huntingdon
    • 3.2 mv6
« Reply #10 on: 08 August 2011, 13:29:19 »
thanks for all replays
caravan it more then 750kgs
so I need B+E  :y
« Reply #11 on: 08 August 2011, 13:32:46 »
so I need B+E  :y
Only if the MAM of the caravan takes you over 3500 kg.  ;)
MAM of an Omega is, at a guess, around 2200 kg so you should still have room for up to 1300 kg.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
I like red cars
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
« Reply #13 on: 08 August 2011, 17:09:52 »
migs can tow 1700 kg , thats the limit
dieseldonicely
shadwell1981
  • leeds, west yorkshire
  • welsh man in town!!
« Reply #14 on: 08 August 2011, 20:34:04 »
i passed my test in '99 and have been towing with a '04 frontera olympus ( sadly p/x ) and 4 berth elddis. i got pulled into a check stop on the m5 last year. only thing they were worried about was if the unit was stolen, i was using red diesel and not over weight (i always tow to regs of car and van) nothing was ever mentioned about licence. they did do a driver check and said nothing. dont think they knew regs!
 when i checked with DVLA i was told my unit must not weigh more than 3500 kg nothing else! best place for advice is the caravan club legal department. what they dont know about towing and licences is not worth knowing. not got a van atthe moment so not towed with omega. hope 2.5 TD manual is up to job.
Pages: [1] 2 3  All   Go Up
