Author Topic: Very sick Pug 206 HDi  (Read 4492 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Very sick Pug 206 HDi
« Reply #15 on: 10 August 2011, 22:11:17 »
blocked oil filter?
twiglet
  • Norwich, Norfolk
« Reply #16 on: 10 August 2011, 22:36:35 »
It wasnt the sump plug he took out to drain the oil, so the possible lack of oil is a red herring.
Something blocked or restricted air to the engine and it was running on neat diesel ?
Thats half a car wash to Albs!  :y
He actually drained the gearbox oil, and then filled the engine with oil!
I drained the engine completely tonight and got just under 9 litres of oil out! Mr Haynes tells me it should hold 4.25 litres!!!  :o
Anyway, gearbox now filled with nice new oil, and engine fitted with another new filter, the correct amount of oil, and new fuel, air and pollen filters for good measure.  ;)
A good blast around the B roads and any remaining smoke from the back has cleared and she's running as sweet as a nut!  :y
Quite impressive really, and a lucky escape!!  ::)
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #17 on: 10 August 2011, 23:10:29 »
I hope you gave him the Swansea address to send his license to.
I dont think 'everyone' should be able to do an oil change, but damn it........ if you attempt it and mess it up that bad, the only vehicle you should be allowed to travel in is the 'Special Bus'.  ;D
sticka_v8_init
  • Reading
    • 2.5 V6 Tourer
« Reply #18 on: 10 August 2011, 23:24:19 »
Purely out of curiosity, what phrases did you use when explaining it to the plum  ::)
Those are my principles, if you don't like them I have others.
« Reply #19 on: 11 August 2011, 08:20:11 »
I hope you've topped the gearbox back up?
twiglet
  • Norwich, Norfolk
« Reply #20 on: 11 August 2011, 08:42:42 »
I didn't give him too much of a hard time tbh. I could see how embarrassed he was, and at least he had a go. Everyone has to start somewhere, and at least he has learnt from the experience!  :y
twiglet
  • Norwich, Norfolk
« Reply #21 on: 11 August 2011, 08:43:35 »
Yep, new sump plug washer and 2 litres of lovely new gear oil!!  :D :y
doug4293
  • greenock, scotland
« Reply #22 on: 11 August 2011, 20:34:04 »
air in the filter due to the rubber hand fuel pump not working properly and uv had to bleed it using the pump and the fuel bleed nipple ?
Signature deleted as it's too big.
Page created in 0.05 seconds with 20 queries.
