Author Topic: Key fob  (Read 2656 times)
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
Key fob
« on: 18 August 2011, 08:31:13 »
 I've just sent my key fob to Martin Imber to be rebuilt, taking the key part off. Thing is, should I be able to start the car with the fob missing, just using the key part???
     I open the door, alarm goes off, start engine, alarm stop's. Is that right?? :-/ :-/ :-/
« Last Edit: 18 August 2011, 08:32:23 by DaveA »
Regards
    Dave
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Key fob
« Reply #1 on: 18 August 2011, 08:42:44 »
Sounds about right to me.
I like red cars
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Key fob
« Reply #2 on: 18 August 2011, 08:51:25 »
As long as the Chip has not being removed from the blade/horseshoe part I dont see why it dont start....
speedy_ns
  • Novi Sad Serbia
    • Omega B 2.5 DTI
Re: Key fob
« Reply #3 on: 18 August 2011, 08:56:02 »
If I'm corect alarm won't be off until you press the button on the transponder, if you unlock it by a key, you will be able to start the engine, but alarm will still be on.
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Key fob
« Reply #4 on: 18 August 2011, 09:03:09 »
I am pretty sure the alarm will go off once the ignition is turned on  :y
speedy_ns
  • Novi Sad Serbia
    • Omega B 2.5 DTI
Re: Key fob
« Reply #5 on: 18 August 2011, 09:22:32 »
I tryed with my Omega and it didn't  :question
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Key fob
« Reply #6 on: 18 August 2011, 09:36:31 »
I dont like electrics but as far as I know the key fob unlocks the central locking.
The key blade goes into the ignition barrel to enable you too turn it. The Chip speaks to the Transponder (which sits around the ignition barrel) to turn off the immobiliser.
I could be wrong in which case I know I will be put right  ;D
« Last Edit: 18 August 2011, 09:38:58 by Loo-knee »
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Key fob
« Reply #7 on: 18 August 2011, 09:43:50 »
More or less correct :y
I like red cars
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Key fob
« Reply #8 on: 18 August 2011, 10:12:59 »
That's how mine works. I've got 2 working remotes, but only one of them actually locks/unlocks the car. I suspect that the one that doesn't work wasn't actually for my car, and got mixed up at the dealer before I bought it. The key's good though, so I could just be confused.
Re: Key fob
« Reply #9 on: 18 August 2011, 10:22:52 »
Have you tried re-synching it as per the manual?
Auto Addict
  • North Birmingham
    • Astra K Elite ST
Re: Key fob
« Reply #10 on: 18 August 2011, 10:24:57 »
He's sent the fob to MB for repair.
I like red cars
Re: Key fob
« Reply #11 on: 18 August 2011, 10:40:39 »
Keep up AA... Not aimed at the op but at another member ;) ;)
Martin_1962
Re: Key fob
« Reply #12 on: 18 August 2011, 10:40:45 »
I reckon he has dropped the immobiliser chip
Martin_1962
Re: Key fob
« Reply #13 on: 18 August 2011, 10:41:18 »
reread
This is correct
DaveA
  • Leicestershire
Re: Key fob
« Reply #14 on: 18 August 2011, 11:04:48 »
reread
This is correct
Thanks All
        I've just found the chip on the key.  :y :y
Regards
    Dave
