Author Topic: Brakes next...  (Read 3785 times)
Re: Brakes next...
« Reply #15 on: 26 August 2011, 08:18:47 »
Its well known fat people need good brakes  :y
;D Now remind me, where did I tell you to stick your stands again...? Big head!   ;D
 :P
Just you wait.  I was a 32" waist in uni :y
Up until my mid 20s, I was 28" and 9.5st.
I hate to say 'I told you so', but I have told the useless student several times over the years that all of a sudden the weight would go on  ::)
It certainly will :-[ :-[ ::) ::) :D :D
Re: Brakes next...
« Reply #16 on: 26 August 2011, 08:19:59 »
I put it down to the inboard face being more exposed to damp and splashing under the car...  :-/.  The tin guard doesn't extend to the bottom of the disc, so some is exposed...???  :-/
I don't buy that - the brakes will knock off the rust long before it can pit.
The rears don't suffer the same fate.
I wonder if its related to floating caliper, esp as it ages, and probably a bit of wear on the caliper pins, and the forces exerted on them  :-/
Re: Brakes next...
« Reply #17 on: 26 August 2011, 09:02:01 »
More likely I would have thought... On older FC setups you can see the caliper move slightly towards the front (in the "wrong" direction) when the brakes are applied ;)
Re: Brakes next...
« Reply #18 on: 26 August 2011, 09:11:08 »
 :P
Both Cripple & the fat admin have met my Dad, he is what a good.. 1/4 stone heavier than me?  :P :P  :D
Re: Brakes next...
« Reply #19 on: 26 August 2011, 09:12:43 »
 :P
As I could not post anything positive on your thread, I thought I would take the pish  ;D
I've only ever fitted standard GM (TC not OEM) to mine, they do the job. But then again its not got enough power to really use the brakes.
Re: Brakes next...
« Reply #20 on: 26 August 2011, 09:20:55 »
 :P
Doesn't mean you'll definitely be like it though ;) ;)
