Pages: 1 2 3 4 5 6 7 [8]   Go Down
Author Topic: Need a Lambda sensor  (Read 15837 times)
Re: Need a Lambda sensor
« Reply #105 on: 24 August 2011, 18:18:15 »
This is the map as I found it.
Not too bad considering it's a standard map (the multipliers are in the wrong place to be the one I did last ;)) but needs some work ;)
Take it a little steady at the top end until the weekend... We'll get it spot on :y :y
I suspect his revs sit at a very steady 6750rpm...
His engine, not mine ;D ;D
Now thats just wrong... The correct fraze is "it's not MY rather engine.. "  ;D
Been careful, honest.  :-/
Is you gayPad set to Yankeeland.  Phase, dear boy, phase....
« Reply #106 on: 24 August 2011, 18:32:17 »
You want Chris to turn from a solid to a gas?
« Reply #107 on: 24 August 2011, 18:43:28 »
My laptop is HP. Its Yankee. It is phased by words like phrase.
« Reply #108 on: 24 August 2011, 21:58:38 »
Is you^ gayPad set to Yankeeland.  Ph^ase, dear boy, ph^ase....
Bloody pedant. Has your Yankee lappy got a sticky r?
« Reply #109 on: 24 August 2011, 22:25:42 »
In fairness to the soon-to-be-rare HP laptop, I was laying in the bath at the time ::)
« Reply #110 on: 24 August 2011, 22:37:43 »
So yes then!  ;D
« Reply #111 on: 25 August 2011, 09:34:21 »
So yes then!  ;D
That's definitely a mental image I didn't need.. Where's the hurling smiley when you need it?  ;D
« Reply #112 on: 26 August 2011, 20:09:29 »
Fuel trims showed +5 and + 11 mid week. Now showing +1 and +5 as of tonight.
Worth going to 2.1mill jet size? Guessing not?
« Reply #113 on: 26 August 2011, 23:23:14 »
Leave well alone, IMHO. 5% fuel trim is perfectly acceptable and no reason to go larger unless it's going lean on full throttle. :y
Pages: 1 2 3 4 5 6 7 [8]   Go Up
