Author Topic: MOT questions  (Read 1960 times)
MOT questions
« on: 26 August 2011, 21:51:04 »
How many can you get correct.
1. Your bumper has been seriously damaged in an accident so you have taken it off and the bumper irons stick out dangerously. Would this cause an MOT failure?
2. Your battery is loose and a fire could result because the live terminal could spark to earth. Would that result in an MOT failure?
3. Your spare tyre is brand new but has a puncture. Would that result in an MOT failure?
4. Your handbrake requires 7 ‘clicks’ before it engages and operates the brake. Would that pass the MOT?
5. Your odometer failed when it registered 45063 miles, which was just after the last MOT. Would that result in an MOT failure?
6. Your vehicle has had its catalytic converter removed and replaced by a normal exhaust silencer but passes the emissions Test. Does it fail the MOT because it hasn't got a catalytic converter when it should have one?
7. Your car has separate side-lights and headlamps. There are no sidelights in the headlamps. When the side-lights are switched on, one of the headlamps illuminates. Is that an MOT failure?
8. Your vehicle has four tyres which are correct, matched in every respect and correctly fitted except that the tread patters are all different. Will this result in an MOT failure?
9. There is a crack in your car’s windscreen travelling upwards from the bottom of the screen directly in front of the driver. It extends 15mm into the part of the screen swept by the wiper but is not directly in the driver’s line of sight when driving. Will that result in an MOT failure?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: MOT questions
« Reply #1 on: 26 August 2011, 22:35:06 »
1 yes
2 no advisory
3 no
4 yes so long as there is still reserve travel
5 no
6 I think no at the moment but yes come january
7 yes
8 no
9 yes
how did I do ::)
other rides
Re: MOT questions
« Reply #2 on: 26 August 2011, 22:38:41 »
7 correct
henryd
  • west cornwall
Re: MOT questions
« Reply #3 on: 26 August 2011, 22:49:45 »
7 correct
not too bad then ;)
other rides
Re: MOT questions
« Reply #4 on: 26 August 2011, 23:58:47 »
1. No
2. Yes
3. No
4. Yes
5. No
6. Yes
7. Yes
8. No
9. No
And does a faulty door strop / stop fail an MOT? tester unsure so passed.... :-/ :-/ :-/
r1
  • nottingham
Re: MOT questions
« Reply #5 on: 28 August 2011, 17:46:22 »
1 yes
2 yes
3 no
4 yes
5 no
6 no
7 yes
8 no
9 yes
9
Re: MOT questions
« Reply #6 on: 29 August 2011, 09:36:16 »
1 No, because the sharp edge isn't caused by damage ::) :o
2 no, advisory
3 no
4 yes so long as there is still reserve travel and advise. Also depends on efficiency.
5 no and advise
6 Not currently, but advise.
7 yes
8 no
9 Depends on Tester. Should do but if not in line of sight it may get passed with advisory
« Last Edit: 29 August 2011, 09:39:25 by Lazydocker »
