Author Topic: Can you buy the scuttle panel foam?  (Read 1873 times)
Missy_MV6
« on: 27 August 2011, 16:08:05 »
Hi guys well whilst my hubby was stripping the car down to remove the dis pack today he noticed that there was water coming from the scuttle.He removed it all and the foam insert was wet through and basically falling to pieces.Can the foam insert be bought seperately or do you have to buy the whole lot?
Angie
Re: Can you buy the scuttle panel foam?
« Reply #1 on: 27 August 2011, 18:32:51 »
Not sure if you can, suspect it comes with scuttle which will be £££.
Its worth putting a small amount of sealant around the base of the wiper arm, thats where water leaks through  :y
Missy_MV6
« Reply #2 on: 27 August 2011, 20:24:22 »
Ah thats brilliant thanks very much  ;)
Angie x
« Reply #3 on: 28 August 2011, 12:25:38 »
Yes, seal it up and the heat of the engine will dry the foam out over time.
« Reply #4 on: 28 August 2011, 19:29:39 »
Often the leak is actually between the screen and the screen's seal.  Usually obvious, as the seal feels dettached.  It just pushes back on, although its a bit tight.
« Reply #5 on: 28 August 2011, 21:42:23 »
Grab the scuttle and wiggle it, if the screen seal moves away from the screen it's loose and scuttle needs removing to fit the seal correctly. As said, it just clips on.
All of the 3.2's we have converted to LPG have had a loose windscreen seal, allowing water to drip directly off the screen onto the back of the engine/coil pacs. Very common ime.
Missy_MV6
« Reply #6 on: 29 August 2011, 11:52:59 »
Okay thanks guys,waiting for the dis pack to arrive and then the hubby will check the seals when hes on with fitting the new pack.
Angie x
