Author Topic: Parts for X30Xe  (Read 4636 times)
Ken T
  • Stockport
Re: Parts for X30Xe
« Reply #15 on: 22 August 2011, 22:11:07 »
It was only a few degrees out, not much but....
Ken
Re: Parts for X30Xe
« Reply #16 on: 22 August 2011, 22:28:49 »
Whether the locking wedges will slide in is probably a reflection on how accurately they have been cast. Many kits aren't that great. It certainly doesn't mean the timing is incorrect. The only reliable indicator of the timing is by offering up the binocular shaped tool with the markings on. :y
300is
  • South Africa
Re: Parts for X30Xe
« Reply #17 on: 30 August 2011, 06:14:06 »
hi Guys,
Need some advise. How do i take out the oil pipes that feed into the oil cooler?
The one is easy to come out but the other one, i cant even get a spanner to fit in there
Re: Parts for X30Xe
« Reply #18 on: 30 August 2011, 10:43:51 »
You'll be more likely to get a response if you start a new, appropriately titled, thread.
However, the answer to your question is that you need a "crow's foot" spanner or socket adaptor.
See the maintenance guide for more details.  :y http://www.omegaowners.com/forum/YaBB.pl?num=1221081908
300is
  • South Africa
Re: Parts for X30Xe
« Reply #19 on: 30 August 2011, 12:56:06 »
Thank you  8-)
