Author Topic: 2004 astra g central locking help needed plz  (Read 2263 times)
Shark1e
  • Stoke on Trent
    • Meega 2.5TD-CD Estate
« on: 29 August 2011, 16:29:53 »
Hi all,
Trying to code a key for my mates astra g 2004,
my "My Naff Code Reader" has found and coded the brand new key from vx and the car starts fine,
problem is i can't get the central locking to work from the new key although it works with the original key no problems,
there are 4 keys coded to the car although he only has 2, the original is classed as key 3 and the new one is now key 4,
i'm guessing that erasing all keys and recoding so they become keys 1 and 2 won't cure the central locking issue on the new key.
so anyone who can shed some light on where i'm going wrong would be appreciated.
tried the new key in ignition on number 1 position and pressing or holding central lock buttons to no avail
also changed battery with original and original key works with new battery so not the battery.
any help please
thanks rob
« Last Edit: 29 August 2011, 16:31:02 by shark1e »
2.5 cdtd omega 1999 manual estate Chipped and poorly at the moment -  is there a doctor in the house
Re: 2004 astra g central locking help needed plz
« Reply #1 on: 30 August 2011, 09:53:16 »
Can you see the ecu detecting a key press of the new remote under live data?
Shark1e
  • Stoke on Trent
« Reply #2 on: 30 August 2011, 16:13:22 »
Hi mate. not sure where to look for live data info. do you mean export data to file? not had this "My Naff Code Reader" long.
managed the transponder ok. not sure if i enter body/central locking then choose something in there?
not got an "My Naff Code Reader" manual.
any ideas appreciated.
ta rob
Shark1e
  • Stoke on Trent
« Reply #3 on: 30 September 2011, 14:51:33 »
just to update, i had not entered the correct "My Naff Code Reader" menu to register a new remote, all sorted now.
