Author Topic: Five Years on  (Read 1977 times)
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
Five Years on
« on: 07 September 2011, 11:41:33 »
   September marks five years of owning my Mig.
In that time I have changed the Cambelt and water pump twice, the rocker cover gasket twice, replaced the small breather pipe, the exhaust manifold gasket once, the exhaust to the cat back, front wheel bearings, front disc & pads rear road springs sounded like a shot gun when it snapped, plus the normal oil changes and a couple of sets of tyres. Thanks to OOF I've been able to do 80% of that myself :y
   Just completed 90,000 miles, I've done 52,000 of them. Is this reasonable amount of work or is it excessive :question :question
« Last Edit: 07 September 2011, 11:44:23 by DaveA »
Regards
    Dave
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Five Years on
« Reply #1 on: 07 September 2011, 12:10:09 »
I dont think any work you do to your own car is excessive, saves shed loads from the Garage, so well done, give your self some stars  :y :y
By the way hope youve done some oil changes in that time.  ;)
Chris.
« Last Edit: 07 September 2011, 12:32:03 by zirk »
Re: Five Years on
« Reply #2 on: 07 September 2011, 12:19:37 »
I dont any work you do to your own car is excessive, saves shed loads from the Garage, so well done, give your self some stars  :y :y
By the way hope you've done some oil changes in that time;)
Chris.
It would appear so  ;) ;)
« Last Edit: 07 September 2011, 12:20:08 by Andy_B »
Abiton
Re: Five Years on
« Reply #3 on: 07 September 2011, 12:24:08 »
I'd say you've done pretty well.   Surprised not to hear mention of wishbones in your list, nor handbrake woes.
Re: Five Years on
« Reply #4 on: 07 September 2011, 12:34:28 »
My Thoughts:
In that time I have changed the Cambelt and water pump twice - Standard Service items so ok
The rocker cover gasket twice - Unusual unless the breathers were a bit clogged and would be dependent on oil change history probably rpior to you obtaining it,
Replaced the small breather pipe - Ok given the above cam cover gasket jobs
The exhaust manifold gasket once - A known issue with these engines although its normaly due to the manifold/studs.
The exhaust to the cat back - Fine - service items
Front wheel bearings - Not to common but they can get a bit of play in them
Front disc & pads - Service items so fine
Rear road springs - Unlucky but given the state of the roads around Melton, no surprise
Normal oil changes - Service items so fine
A couple of sets of tyres - Again wear items so fine
I have always said, a car is only as good as its last owner!
zirk
  • Epping Forest
Re: Five Years on
« Reply #5 on: 07 September 2011, 12:34:33 »
Specksavers again  :D
Stallion
  • Romford
    • 3.2 Irmscher Elite
Re: Five Years on
« Reply #6 on: 08 September 2011, 07:22:34 »
Pretty reasonable list for a 5year period..  :y if anything be proud of your miggy!!
