Author Topic: this is not oil thread  (Read 8341 times)
Re: this is not oil thread
« Reply #15 on: 19 September 2011, 09:47:29 »
It could just be the oil pressure switch being faulty so Kevin's suggestion of plumbing in a gauge seems a good one :y
Low probability but, hope springs eternal!
But yes, a gauge would be a wide move
Martin_1962
« Reply #16 on: 19 September 2011, 09:53:52 »
Ah, is this a "no sump" engine?
It has a sump, just no sump drain plug.  ;)
You turn the car upside down to drain the oil out
« Reply #17 on: 19 September 2011, 09:55:53 »
Sounds like it may need shorter change intervals.
I guess also that its an oil suck setup which tend to resul in sludge in the sump more (sadly).
I dont like the sound of the flickering lamp, they normaly come on at the 12-15psi mark where as the oil pressure even when hot should be 30+.
Removal of the sump was one of the first things done when the light started flickering, and the sump itself was clear of all sludge.
(just loads of condensation/mayo on the walls)
Only problem was something like Hermatite blue had been put on with a shovel and the excess inside the sump had fallen down & been picked up by the pump.
Removing this lot made a huge difference - the cam chain has a hydraulic tensioner so even though it's still a bit noisy - it's loads better that it was.
« Reply #18 on: 19 September 2011, 09:57:36 »
It could just be the oil pressure switch being faulty ....
New switch fitted ....... which COULD still be faulty  :-/
« Reply #19 on: 19 September 2011, 10:00:34 »
Tried that, but lost the washer water too!  ;D ;D ;D
« Reply #20 on: 19 September 2011, 10:09:07 »
If this has happened before then clearly the oil pressure is marginal. If the switch has been changed it's unlikely to be that. :-/
I think I'd be looking to check the pressure relief valve next. If it's had all that sealant in the pickup it's not unlikely that some has ended up jammed in the relief valve.
« Reply #21 on: 19 September 2011, 10:12:17 »
Good idea.  :y
« Reply #22 on: 19 September 2011, 10:24:53 »
Do you know what pressure the switch activates at? On the MR2 it comes on at 3.8psi, which is frighteningly low (as many people say on that forum, it's really not an oil pressure warning lamp, it's a "Please visit the dealer for a new engine" lamp!) - I'd be worried if it was flickering and that's it's activation point.. if it were higher (say, 10psi or so) I might not worry so much.
« Reply #23 on: 19 September 2011, 10:27:28 »
Sounds like you have a few thinsg to check then Andy.
Given the pics you posted, I would not be overly surprised if some bearing wear had occured and hence the oil pressure issues.
« Reply #24 on: 19 September 2011, 11:17:46 »
Do you know what pressure the switch activates at? ....
No. I'll see if I can find out.  :)
« Reply #25 on: 19 September 2011, 11:20:34 »
Mmmm  :( That's what I'm frightened of.  :'( :'(
Goes to show how much better a well serviced car is compared with one that isn't.  ::)
Maybe an oil change with hypoid 90 & sell the bugger  ::) ::)
« Reply #26 on: 19 September 2011, 11:26:01 »
If this one is OEM spec. it suggests not a lot.  :-/
http://seekpart24.com/hella/oil-pressure-switch-6zl008280061?c=100478&at=13106
Switch Pressure [bar]: 0,15-0,35
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #27 on: 19 September 2011, 12:19:23 »
Autodata suggests that oil pressure should be 2.0-2.5 bar at 750-950 rpm
HTH :y
other rides
« Reply #28 on: 19 September 2011, 12:29:14 »
Kin ell, thats bugger all of bugger all!
I thought the Vx one was low at 0.5 Bar
« Last Edit: 19 September 2011, 12:32:30 by Mark »
« Reply #29 on: 19 September 2011, 13:19:56 »
Yeah, much like the Toyota one it's not a "warning: there's something amiss" light it's now a "congratulations, you're boned!" light  :-/
Granted if it's only flickering at idle it's probably not doing too much damage - as long as the pressure is healthy off idle. But what cars come fitted with oil pressure gauges these days?  :(
Pages: 1 [2] 3 4  All   Go Up
