Author Topic: So what have you done to your car today?  (Read 8291509 times)
0 Members and 54 Guests are viewing this topic.
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #10920 on: 10 August 2015, 16:32:02 »
The only real solution to 0420 and 0430 codes on a 3.2 (and 2.6, though less common) is to move the sensors.
Cataclean at best will only be a short term solution.
Have a set in the parts shed that need sensors moving :y
I'm going to keep my mouth shut in the future, went out this morning to go to Scotland's secret bunker with a full car of wife daughter and two granddaughters, got 5 min into trip and EML come on, so stopped and reset with Maxcom and all was fine, coming home stopped in traffic and the spanner sign come on as I pulled away after a clunk ? Stopped and checked with Maxcom and no codes. Turn engine back on all is fine. I have had this once before about six months ago ? Think it's time for a ATF change.
    • 530D M Sport, 330i Coupe
« Reply #10921 on: 10 August 2015, 17:50:45 »
.....Car is now lowered 30mm with Bilstein B4's and Eibach springs and I think it looks the doggies danglies :y  ....car handles like a dream,goes round the twisties like it should
I do love that exact same setup on my 3.2, just feels fantastic to drive.
ted_one
« Reply #10922 on: 10 August 2015, 17:59:10 »
Agreed...got that set up on the 3.0 as well,certainly the way to go when it comes to fixing up a shagged out suspension :y
Lagondanet
  • Bedfordshire
  • The Omega is gone!
    • Lagondanet
« Reply #10923 on: 10 August 2015, 21:42:34 »
Latest.
Topped up coolant last night. 45 miles to Hammersmith this morning, when parking dropped at least half a litre of coolant, just in front of front driver's side wheel. Is that where expansion tank exits. Got back this evening, traffic not too bad, but temp gauge 90-95 most of way.   Few drops when I parked, and expansion tank took a litre to top up. Felt and smelt hot (coolant) on driver's side.
Going to get a second Vx opinion on Wednesday but would value your input.
« Reply #10924 on: 10 August 2015, 22:10:28 »
Latest.
Possibilities on that side are:
HBV
Expansion Tank
Radiator
My money would be on either radiator or expansion tank :-\ What state is top of tank in? they can crack around the filler...
« Reply #10925 on: 10 August 2015, 22:33:42 »
Could be the recirc electric pump
« Reply #10926 on: 10 August 2015, 22:40:30 »
Only runs when engine is off and climate on...
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #10927 on: 11 August 2015, 09:07:10 »
Latest.
HBV
Expansion Tank
Radiator
On journey to London today went early so little congestion. 90 degrees. No loss of coolant but slight seepage/drops on top of expansion tank. Could be cap? Can't see any cracks.
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #10928 on: 11 August 2015, 09:08:24 »
Could replace expansion tank & cap?
« Reply #10929 on: 11 August 2015, 09:14:57 »
Tank cracks aren't always obvious, but follow the moulding seams around the filler. Eventually they open out and all becomes plain.
Worst case, you end up with a nice clean header tank/cap, but if it solves the issue then it's alot cheaper than a double headectomy ;)
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #10930 on: 11 August 2015, 09:18:04 »
See how we go this evening when there will be more traffic. How big is the job to replace HBV?
« Reply #10931 on: 11 August 2015, 09:19:57 »
Not very. Can be fiddly, depending on the approach used... plenum off or scuttle off, but otherwise it's three hose clips :y
Lagondanet
  • Bedfordshire
    • Lagondanet
« Reply #10932 on: 11 August 2015, 09:28:09 »
Thanks for the info.  :y
EMD
  • Noofhampton
    • 95t
« Reply #10933 on: 11 August 2015, 17:43:47 »
Picked up 2 ton of box section offcuts today from a metalworks in Daventry , the omega went well in the bends on the way back  ::)
Omegatitis
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #10934 on: 11 August 2015, 19:31:29 »
Walked past it half a dozen times,as is usual.Advertised it for sale in the local branches of 4 major supermarkets.
