Author Topic: So what have you done to your car today?  (Read 8499173 times)
0 Members and 12 Guests are viewing this topic.
« Reply #10995 on: 22 August 2015, 09:44:06 »
Yesterday evening, changed the rear pads and the rear shocks on the Battlebus.
On the upside, its stopped that high pitched squeal.
On the downside, I now know I have a broken spring. 'dangle berries'.
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #10996 on: 22 August 2015, 10:28:15 »
Mot passed yesterday only advisory osf tyre tread low,20 years old this month. :y
EMD
  • Noofhampton
    • 95t
« Reply #10997 on: 22 August 2015, 10:49:53 »
Does not handle very good with boot overloaded  ::)
Omegatitis
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #10998 on: 22 August 2015, 10:59:12 »
The tyre or the car or both ??? :D :D ;)
other rides
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #10999 on: 22 August 2015, 13:09:33 »
i do have a 40yr old tyre in my shed that was on an old austin i bought years ago and was fitted brand new for it's mot and then taken off the road so tread is "as new".
John.
« Reply #11000 on: 22 August 2015, 14:18:42 »
Rear springs replaced on Battlebus this morning, thanks to Marks DTM for the description of how to do it, it was, as he says "piss easy" ;D
Sadly, changing the springs appeared to cause the turbo to fail ;D.  Much smoke, no go ;D
Sorted that quickly, usual split rubber connector that plagues all DTi's.
Contemplating changing the oil, as its been in about 4k, but I think my sugar levels need to recover first, its bloody hot around these parts. That really oppressive humid heat.
And because the sausage and cider festival is on round the corner, I can sit on the drive and listen to the bands :)
« Reply #11001 on: 22 August 2015, 17:28:42 »
Get round there. A few pints of cider will sort your sugar levels out!!  8)  :y
« Last Edit: 22 August 2015, 17:33:38 by Sir Tigger »
« Reply #11002 on: 22 August 2015, 17:49:04 »
But perhaps not the sobriety levels :D
That said, oil changes on the drive are mostly about lyimg down, so perhaps it would be fine ;D
« Reply #11003 on: 22 August 2015, 18:54:51 »
Oil changed in the Battlebus as well, which is pretty straightforward on that, except you need to remove one of the inlet hoses (GM clearly didn't think that one through.
The hardest bit being decanting the 20l drum into the 5l cans, as the pump I bought was less use than a used, split condom smeared in dogshit.
jimbo125
  • Camberley
    • Vauxhall Omega 2.5V6CDI
« Reply #11004 on: 23 August 2015, 01:19:52 »
That useful...wow :D
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
    • 530D M Sport, 330i Coupe
« Reply #11005 on: 23 August 2015, 18:56:10 »
On the 2.6, Fitted new OSF wheel arch liner and applied a good coat of Dinitrol around the inner wing and chassis rail sections, removed self levelling pump and pipework, cleaned, rust converted and painted front crash bar and fitted MV6 bumper.
Failed to remove plugs in bosses to fit lambda's in new position, now soaking in plus gas.
Failed to replace door lock solenoid as it appears I only have two faulty ones left.  :'(
On the 3.2, well I looked at it as I reversed onto the drive.
« Reply #11006 on: 23 August 2015, 19:05:38 »
Doesn't that shag the sensor?
« Reply #11007 on: 23 August 2015, 19:46:26 »
No sensors in them, these are the bosses that Daz welded post main cat on the 2.6's exhaust, I've only just got round to buying two new genuine Lambdas (aborted all attempts to get the originals out!) at the right price, to fit.
« Reply #11008 on: 23 August 2015, 19:52:08 »
Ah, phew!
« Reply #11009 on: 23 August 2015, 19:52:31 »
Where you get sensors from, I have same issue
