Author Topic: So what have you done to your car today?  (Read 6508181 times)
0 Members and 10 Guests are viewing this topic.
ted_one
« Reply #11100 on: 19 September 2015, 22:27:57 »
Thanks for the heads up,I'll nip in there on Monday and check them out :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #11101 on: 20 September 2015, 19:07:38 »
Refitted battery which had gone flat and inflated rear tyres which had done the same as car is rarely used,not moved an inch since 20th August.
T.m.f
    • 4wd
« Reply #11102 on: 21 September 2015, 11:25:27 »
Started on tmf,rad,inlet,exhaust,wiring loom,alternator and cambelt removed,now need to remove cam cover,head,starter,undo engine mounts,gearbox bolts and engine out :y
1996 300tdi manual discovery,the weekend mud toy and tin tent tower
The devil child ,aka mk2 2006 1.6 tdci focus
EMD
  • Noofhampton
    • 95t
« Reply #11103 on: 21 September 2015, 16:13:15 »
Ordered a new windscreen to be fitted tomorrow  :)
Omegatitis
« Reply #11104 on: 21 September 2015, 18:17:01 »
Absolutely sod all. Not even driven it, as I've hurt my right foot again :(
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #11105 on: 22 September 2015, 08:54:30 »
Rear shock top mounts changed yesterday and it looks like that has stopped the knocking from the rear of the estate, oil change done before the drive to Scotland this Friday for granddaughter time this weekend, must find time to correct the sat-nav on the estate after the last Scotland trip.
EMD
  • Noofhampton
    • 95t
« Reply #11106 on: 22 September 2015, 17:08:58 »
New windscreen fitted , no rust under the screen at all . New trims fitted also , ready for the frost now  :)
Omegatitis
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #11107 on: 22 September 2015, 21:19:00 »
Fitted new wishbones with polys in new droplinks and unexpectedly track rod ends that all 4 rubbers had split on them.
That will teach me to fit cheap and nasty ones last time ;D ;D ;D
« Reply #11108 on: 25 September 2015, 14:16:59 »
Driverside wheel arch and sill all done... (igoring the crappy old suspension that is ::))
Just the nearside to finish off and that will be another job jobbed 8)
« Last Edit: 25 September 2015, 14:21:19 by Harris K Telemacher »
BazaJT
« Reply #11109 on: 25 September 2015, 18:45:20 »
Forgot to say that while tyres were inflating I had the bonnet up checking for leaks/smoke etc[engine was running for fag lighter powered compressor]and when it came down onto tickover heard a new noise from front of engine-sort of a "catching"type noise.held a socket extension on cam belt cover stuck my thumb on the end and put my ear to it,it's not a loud noise and can't be heard until engine settles to idle but appears to me to be slightly louder on off side than near side.So cam belt shredding and catching on cover or tensioner/pulleys giving up?Damn car seems to have a knack of breaking without actually going anywhere!!
  • Auckland
    • Mazda MPV
« Reply #11110 on: 25 September 2015, 22:06:01 »
More likely that the auxiliary belt was under an unusually heavy strain due to the air compressor loading up the electrical system.
BazaJT
« Reply #11111 on: 26 September 2015, 15:13:45 »
I hope you're right!I'll check that out tomorrow without electrical loading.
  • Auckland
    • Mazda MPV
« Reply #11112 on: 26 September 2015, 16:35:39 »
Mine makes a noise like that after a cold start (and Gixer has the same concern). The noise goes away after a minute or so in a car that is in regular use. Your battery is probably still low on charge so the noise might continue  :-\
BazaJT
« Reply #11113 on: 26 September 2015, 21:57:26 »
Not necessarily as bad/urgent as I thought then if that turns out to be the case.Here's hoping!
  • Auckland
    • Mazda MPV
« Reply #11114 on: 26 September 2015, 22:37:24 »
If you have any worries about it then it only takes a moment to slip the aux belt off. Run the engine without it for a minute or so & see if the noise is still there.
