Author Topic: So what have you done to your car today?  (Read 6471042 times)
0 Members and 7 Guests are viewing this topic.
jimbo125
  • Camberley
    • Vauxhall Omega 2.5V6CDI
« Reply #11550 on: 13 December 2015, 20:33:04 »
HGs are rare to go on miggys. More like to have it corrode away until its just the fire rings but these normally are bullet proof.  My fear is maybe the head itself :'(
Thanks for the advice will only know when I get the heads off and check them that will give the ultimate answer. Cheers :y
2.5V6 Had it since 2002, what a beast, worth the time and effort to keep it road worthy. Vauxhall bring them back!!! Laser timing kit for OOF member hire
  • Auckland
    • Mazda MPV
« Reply #11551 on: 13 December 2015, 21:18:44 »
Why the head?
My first Omega was a 2.5 V6 and that suffered a head gasket failure at the rear of bank 2. I was expecting to find a leaking core plug as the coolant appeared to be leaking from behind the ignition coil bracket.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #11552 on: 14 December 2015, 09:06:40 »
Fitted a new (autodimming Vectra C) rear view mirror. This would have been easier were there not a load of black sillycone sealant dolloped about the place by the Autoglass monkeys who in spite of my explicit instructions 'do not attempt to fit the rear view mirror' they did, it fell off, so they tried to glue it in place!  ::)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« Reply #11553 on: 14 December 2015, 12:43:47 »
Why the head?
Just saying that it is very rare for the fire rings to go on a miggy engine.  More common for leaks toward the exterior like you (and I) had in the past.  I have seen various HGs completely corroded to the point where just the fire ring are left but they were intact.  Which is why I would be questioning the block unless on strip down there was clear evidence of a leak through the HG. :y
EMD
  • Noofhampton
    • 95t
« Reply #11554 on: 14 December 2015, 13:56:58 »
Scraped 2 dustpan's full of muck and debris out from under the rear arches on the mazda  ::) Went to replace the air filter , didnt need doing ..clean as a whistle  ::) Oil clean and running as quiet as a mouse  ::) Topped the washer fluid up with proper stuff  ::)
Omegatitis
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #11555 on: 14 December 2015, 15:41:09 »
Fitted the new HID bulbs... The difference is night an day, pardon the pun  ::) :y
« Reply #11556 on: 14 December 2015, 15:58:32 »
Between your old HID and the new, or you've gone from Halogen to HID?  :)
Boatboy
  • St Albans
« Reply #11557 on: 14 December 2015, 16:06:56 »
New coolant bottle - I can now see what's in there
Changed oil and filter element - Someone has a significantly different impression of 15NM to mine ::)
Checked atf level - Filter and fluid change now moved up the to do list.
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #11558 on: 14 December 2015, 16:07:50 »
Old HID bulbs swapped for new ones  :y
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #11559 on: 14 December 2015, 17:48:24 »
Some say(top gear mode on)that HID bulbs lose around 10% efficiency per year which must be 'dangle berries' as they wouldn't work after ten years would they ??? :D :D ;)
other rides
« Reply #11560 on: 14 December 2015, 18:17:31 »
mathematically incorrect statement I'm afraid .. even loosing 10% a year they would last forever .. although very inefficient after a few years ...
Year 1 100% lose 10% (10) becomes
Year 2 90 % lose 10%  (9) becomes
Year 3 81 % lose 10%  (8.1) becomes
Year 3 72.9 % lose 10% (7.29) becomes
year 4 65.61 % lose 10% (6.51) becomes
year 5 59.04
etc
etc
etc
and NEVER reaches zero
« Reply #11561 on: 14 December 2015, 18:19:22 »
Worth while?
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #11562 on: 14 December 2015, 18:32:51 »
Worth while?
Now that I've seen first hand the difference I would recommend changing them, not for cheap Chinese ones as some would recommend  ::), I highly doubt I'd have bought them at the original VX RRP price though. £109 each or that could have been for two bulbs not 100% sure, that's without TC.. Sure Taxi Al said he got some cheap Osram from somewhere though..
Only thing to do now is find some replacements for the main beam they are looking far too yellow!
« Reply #11563 on: 14 December 2015, 18:38:22 »
Worth while?
Yes, IME. But buy branded from reputatable suppliers (not egay, euroshiteparts, acmebackstreetwholesalers etc)
« Reply #11564 on: 14 December 2015, 19:16:48 »
Worth while?
Don't suppose you can get more at the price you sourced them for?
Worth while?
I've never really had any issues with ECP
