Author Topic: So what have you done to your car today?  (Read 8496727 times)
0 Members and 13 Guests are viewing this topic.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #13620 on: 13 January 2017, 20:33:31 »
 had two tyres fitted {black and round} then went home and fitted new GM pads front and back, then noticed it stooooops now. :y
Hoof'land storeman.
mantaray
  • Coventry
« Reply #13621 on: 13 January 2017, 22:09:44 »
New belts and tentioner fitted to 2.5TD
2.6 CDX Auto Estate,
71 Opel Manta A Series 2.5 V6
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #13622 on: 14 January 2017, 17:01:34 »
Fitted NCDC & CID to replace NCDC & GID. Removed pesky EML light while I was in there. Keep clearing the code, and it comes back within a hundred or so miles. Would rather put it back in for MOT once a year,if need be, than having it lit all the time.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #13623 on: 14 January 2017, 18:02:15 »
Did the annual oil and filters. As it has only done 4700 miles, I was tempted to leave it, but the slightly lumpy idle suggested new plugs: it turns out that 2 are knackered, and another well past its best.
neil74
  • newport
    • 2.6 elite estate.
« Reply #13624 on: 15 January 2017, 00:19:03 »
Mines due a good going over to be honest. but all I did yesterday was to rag the hell out of it.
2boxerdogs
« Reply #13625 on: 15 January 2017, 09:40:02 »
Found & fitted a genuine MB V8 grille badge.
EMD
  • Noofhampton
    • 95t
« Reply #13626 on: 16 January 2017, 10:00:23 »
Took the flat out of the shed  ::) Also the car looks very dirty and needs a good spit and pollish ... roll on spring  :)
Omegatitis
« Reply #13627 on: 16 January 2017, 11:06:30 »
Washed it.
No, that's a lie. Skoda washed it after they bent me overchanged the oil.
« Reply #13628 on: 16 January 2017, 12:15:54 »
Changed the rear shocks for a pair of B4s in preparation for the MOT. Usual thing. First shock came off fine. Other side required me to get out the "Angry tools". ::)
Just got to do the drop links (again!), rear disks, cam belt, air filter, pollen filter, fix the coolant leak, polish the headlight lenses, change the wiper blades... ::)
« Reply #13629 on: 16 January 2017, 12:46:44 »
Be done by tea time then :D
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #13630 on: 16 January 2017, 16:50:05 »
Had 2 Rainsport 3's fitted to the front of the TD Estate. The Enduro 916's that came off had only done 7500, but were all over the place, even with even wear and 4k left in tread. >:(
  • Chatham, Kent
« Reply #13631 on: 16 January 2017, 18:40:36 »
Opened my package of 4 new springs and a heater matrix from ATP. That was mainly so it takes up less space, as I've no idea when I'm going to have time to actually fit them. Although I need the springs done before we go to France in March.
« Reply #13632 on: 16 January 2017, 22:54:02 »
Oh, and I had to go and sit at a desk pushing a mouse around for hours too. ::)
Well, most of that little lot done... aaand the coolant leak is... from the HBV. :( and the Vapouriser. >:(.. and there's a gas leak from the latter too. ::)
Lagondanet
  • Bedfordshire
  • The Omega is gone!
    • Lagondanet
« Reply #13633 on: 17 January 2017, 11:37:49 »
Broke down on A40 West London yesterday pm. Engine cut out. Started again but only went a few hundred yards before cutting out again. Recovered to local garage in Flitwick and await their findings. PITA. Had to take the Adam this am.  >:(
« Reply #13634 on: 17 January 2017, 16:51:12 »
I'd put some money on crank sensor  :)
