Author Topic: So what have you done to your car today?  (Read 8503153 times)
0 Members and 19 Guests are viewing this topic.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #15495 on: 01 January 2018, 11:54:24 »
Nothing. Nor will I. 12 hour shift after 4 hours sleep. I'm cream crackered.  >:(
« Reply #15496 on: 01 January 2018, 14:55:00 »
Oh, and I noticed one of my less than a year old B4 rear shocks is oil misting. >:(
You're the second person I've heard say that in the last couple of weeks.  Has Bilstiens' quality gone down the shitter, or are there a lot of substandard copies about?
Remember where you sourced them from?
« Reply #15497 on: 01 January 2018, 14:55:49 »
Failed to update the satnav map. Apparently the USB stick is faulty.
« Reply #15498 on: 01 January 2018, 14:57:40 »
Don't waste your time.
Tandy supply the Nav for Jaguar using stock from 1972.
« Reply #15499 on: 01 January 2018, 14:59:35 »
Mine works very well, thank you, apart from its 7yr old map missing a bit too much (and the shitty early X351 touchscreens being a bit unresponsive).
What would work better?
« Reply #15500 on: 01 January 2018, 15:06:02 »
If it knew where it was going.
If it was aware of junctions that have been in place for forty years.
If it told me to turn left or right rather than have me guess.
If it used proper road names like A14 or B4535 rather then calling it  Derek Johnson Way or similar crap I've never heard of.
If it didn't turn mute when I need information most.
« Reply #15501 on: 01 January 2018, 15:08:35 »
The system in the mighty Signum is far superior.........and that only gets 6/10.
« Reply #15502 on: 01 January 2018, 15:15:22 »
Not suffered these problems, bar taking me through town instead of the 5yr old bypass every time I go to mums.  Although, invariably, I have the voice turned off, and rely on the pop-ups on the dash next to the speedo.
Is yours the In Touch one?  Mine is the older hdd gen 2.1 variant.
My biggest complaint is, unlike Omega/Signum/Vectra/Zafira, you can't enter a destination via the steering wheel, though the Jaguar Voice is incredibly accurate for me, even at very high speed.
« Reply #15503 on: 01 January 2018, 15:20:24 »
My 2013 XFR was equally piss poor which is unsurprising as the system is the same.
As for TMC information......forget it. It either doesn't let me know or sends me in a circle back to where the hold up is.
« Reply #15504 on: 01 January 2018, 15:28:25 »
Was that the In Touch as well, or the older gen 2.1?
No issues with TMC either, which is the usual reason for me enabling satnav - it tells me where hold up is, estimated extra time, predicted clear time, and details of suggested reroute.
Its certainly, unsurprisingly, far better than the NCDC system fitted to Omegas, which in turn I would still pick over *any* handheld unit.
« Reply #15505 on: 01 January 2018, 15:48:27 »
Don't know.
« Reply #15506 on: 01 January 2018, 17:52:03 »
Balance, I think. Certainly had no reason to suspect they weren't genuine at the time.
    • 530D M Sport, 330i Coupe
« Reply #15507 on: 01 January 2018, 20:36:20 »
Started work on a Corsa C 1.2 SXi.  :o
2boxerdogs
« Reply #15508 on: 01 January 2018, 23:02:35 »
Took the wifes Subaru for a run out , really is a very nice car to drive .
« Reply #15509 on: 01 January 2018, 23:49:50 »
Not good news, as we always thought them to be good quality.
