Author Topic: So what have you done to your car today?  (Read 8490557 times)
0 Members and 40 Guests are viewing this topic.
« Reply #15630 on: 23 January 2018, 18:41:36 »
My new ABS ECU for the BMW turned up from Berlin today, so I fitted it and now the ABS light goes out as it should!  :y
The ASC light is on permanently though, but it's getting coded tomorrow so hopefully that'll go out as well....  ::)
« Reply #15631 on: 24 January 2018, 09:26:57 »
Fingers crossed. :y
« Reply #15632 on: 24 January 2018, 09:35:52 »
Not even seen it for over a week  :-[
Buried under rubble in Cornwall? ;D (C'mon, it's not like I have any post count to lose  :P)
As for mine, driven it, just a little bit. Not much last week though as we were in Paris. Today I half expect to find a tree sitting on it if the wind keeps up like it is..
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #15633 on: 24 January 2018, 10:05:44 »
 :D ;D ;D ;D
other rides
« Reply #15634 on: 24 January 2018, 11:54:19 »
Fingers crossed. :y
My code reader says "ASC Button - Not actuated", so hopefully it just needs switching on or actuating!  :y
« Reply #15635 on: 24 January 2018, 16:19:09 »
Fingers crossed. :y
All sorted!  :y  Both the ABS and ASC lights come on and go out as they should and the ABS is operating as it should!  :y
It's only taken 10 months of on and off fiddling with different sensors, bearing/reluctor unit, testing with multi meter, code reader, and even Mr Wood pitching in with his oscilloscope to get to this point!  ::)
« Reply #15636 on: 24 January 2018, 16:23:16 »
Glad it's sorted :y
I found selling mine and using the proceeds to buy another Omega far more efficient  ::) just got to rebuild the suspension now... ;D
« Reply #15637 on: 27 January 2018, 09:36:59 »
I need to fit new pads to back of Battlebus, but its 3C and damp outside.
CBA is currently winning, but its getting desperately close to its MOT.
« Reply #15638 on: 27 January 2018, 09:39:57 »
What are you, man or a mouse? ::) :D
« Reply #15639 on: 27 January 2018, 10:29:56 »
Squeak squeak.
« Reply #15640 on: 27 January 2018, 10:39:38 »
Bugger, its raining now :(
« Reply #15641 on: 27 January 2018, 12:35:19 »
One front corner back together...
Just tother side to do.
But if I ever meet the oppstarding lady bits that fitted the rear bolts with the nut in the subframe, I will fit said subframe up their arse. Probably with the car attached.
Fortunately I had four spare nuts :-X
« Reply #15642 on: 27 January 2018, 13:36:42 »
Made of sugar too? ::) :D
« Reply #15643 on: 27 January 2018, 13:52:48 »
Need to put a new radiator in Mrs KW's MX5 but CBA and manflu are currently getting in the way. ::)
Prior to this year, I can't recall ever having a radiator fail. This year, I've replaced the radiator in the Westfield, the Omega and now the MX 5. >:(
« Reply #15644 on: 27 January 2018, 13:58:47 »
Nancy boy. :)
