Author Topic: So what have you done to your car today?  (Read 8478927 times)
0 Members and 39 Guests are viewing this topic.
twiglet
  • Norwich, Norfolk
« Reply #1605 on: 23 January 2012, 08:09:27 »
Update from the past week or so...
New wheels shod with some lovely new rubber, and fitted to the car.  I had my doubts as to whether they would suit the car, but I'm very happy with the result!!
Also took delivery of some Irmscher and Steinmetz goodies, which will be making their way onto the car shortly!!
All in all, it's coming along nicely!!  ;D
any pics coming soon :y :y
They'll be plenty of pics coming along soon, as soon as I get everything fitted.  :y
« Reply #1606 on: 28 January 2012, 16:38:50 »
Went to the scrapyard and removed a rear door trim strip ....not so easy trying to take off without damaging it  ::) Only 2 migs in the whole yard of about 100 cars  :o i found that ripping the old one off quite easy and the new one put back in its place easy peasy "sorted"  :y
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #1607 on: 28 January 2012, 17:31:58 »
fitted a genuine rocker cover gasket to in laws 2.0 vectra after company who did head gasket put a crap one on that poured oil down onto exhaust, then reffited mates lpg tank and cleaned his car out thats been on my drive for 6 months, hoping it will be gone this week, a afternoon well done
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
« Reply #1608 on: 28 January 2012, 17:36:17 »
At work so a bit limited,but fitted a set of elite alloys,washed it and checked the fluids and tyre pressures.
tgm147
  • Wirral
    • '02 2.2 Omega CD
« Reply #1609 on: 28 January 2012, 18:10:20 »
Today I've filled it up with water again after hopefully sorting the water leak out, I've also covered the 6 inch long crack in the manifold with a load of reinforced exhaust paste until I can afford to fit another one, then I tried to cure the rough idle by checking the breather pipes and the slightly cracked vac hose on the inlet manifold. Now nicely wrapped in insulation tape.  :-\
Water leak appears to have stopped, and the noisy idle has been cured but still got a slight rough running. 2 out of 3 isn't bad!
« Reply #1610 on: 28 January 2012, 18:26:42 »
Colin's wishbones.
...and her rattly polo...  Is annoying me. Pfffff...
Still, had the use of one of these
http://www.easupplies.com/INGERSOLLRAND-W360KL2-Cordless-Impact-Wrench-Kit-p/pt11bc.htm
AV IT!
    • 530D M Sport, 330i Coupe
« Reply #1611 on: 28 January 2012, 19:44:52 »
Cleaned two of the eight unmounted Elite Alloys I have ready for two tyres in the near future. Found that leaving the inner faces coated in WonderWheels for 10 mins, washed off and the process repeated has nearly got them back to a decent finish.
« Reply #1612 on: 28 January 2012, 19:45:34 »
Colin's wishbones.
AV IT!
Swapped my wheels over...  ...the old fashioned way - Orgasmagizmo went flat.
Got rid of the Autogrip tyre, and got a puncture repaired on the Rover.
Contemplated doing the MV6 handbrake, but ran out of daylight.
Corrado1441
  • N.Ireland
    • Vauxhall Omega Elite
« Reply #1613 on: 28 January 2012, 19:58:39 »
Stripped the wooden effect dash pieces out and painted them gloss black.
« Reply #1614 on: 28 January 2012, 22:09:10 »
Colin's wishbones.
AV IT!
What is it with you and that bloody handbrake? Mine is out of adjustment, but only because the drums are grooved badly. It passed the mot btw. Need to back the handbrake adjusters right off to get the discs off. Replace the discs (soon) and will probably be fine. Other than that I've never had to look at a handbrake.  ???
paul.lovejoy
  • Ramsgate Kent
    • wife mad 2.6 cd estate
« Reply #1615 on: 28 January 2012, 22:15:16 »
let wifey have a drive since i got it back from daz :o :o :o :o
tgm147
  • Wirral
    • '02 2.2 Omega CD
« Reply #1616 on: 28 January 2012, 22:39:33 »
Just been out and cleaned off the egg that the local knuckle-dragging lowlife degenerate wastes of oxygen have thrown at it.  >:( >:( >:( >:( >:( >:( >:( >:( >:( >:(
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #1617 on: 29 January 2012, 01:42:51 »
Poly bushed the ARB and fitted new droplinks. (Elite, it'd had a harder life than my pampered MV6). Lemforder ones are a tighter fit than crappy pattern parts. I think I need thinner spanners.
Who the hell said it took 5 mins to change ARB bushes from underneath? Bloody hell! Obviously I didn't want to drop the subframe like Haynes reckons, so both wheels off car in the air, d/l disconnected, no tension on bar, but bloody hell it's awkard!
ABS ecu, exhaust manifold gasket, wishbones, cam covers, this! There's is a pattern going on here! Is there a pleasant job on the omega? Was going to whip alternator off, solder contact and replace bearings, but twas late so another time.
TC and BnQ Trade holder.
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #1618 on: 29 January 2012, 01:59:11 »
Been doing it, doing it, finally got round to disconnecting the power sounder  :y
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #1619 on: 29 January 2012, 02:00:51 »
Interesting choice  ::)
How does that look?
