Author Topic: So what have you done to your car today?  (Read 6384918 times)
0 Members and 10 Guests are viewing this topic.
« Reply #16470 on: 21 June 2018, 21:06:55 »
Fitted a new (pattern) cam sensor on the BMW.  :)
Hopefully I won't be sitting around in anymore supermarket car parks, waiting for it cool down so I can start it!  ::)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #16471 on: 21 June 2018, 21:12:42 »
Fitted a pair of Griffin emblem LED shadow lights to the bottom of the front doors.
CHAVTASTIC !!  ;D
amba
  • Medway towns
    • German V6
« Reply #16472 on: 21 June 2018, 21:20:44 »
Only in Essex..Albs  ;D
Migv6 le Frog Fan
« Reply #16473 on: 21 June 2018, 21:22:56 »
When in Rome Andrew...... ::) ;D
amba
  • Medway towns
    • German V6
« Reply #16474 on: 21 June 2018, 22:04:21 »
Et tu brute  ;D
  • Auckland
    • Mazda MPV
« Reply #16475 on: 21 June 2018, 22:42:06 »
Fitted a new drive shaft to SWMBOs Galaxy   :(
The last three big trips we have done in it have resulted in either limping hundreds of miles home to Cornwall or calling the AA for a ride on a lorry  >:(
1st trip it was the injector wiring loom in the cylinder head. Poxy design leaves too much unsupported wire flapping around in the cylinder head and the push on spade connector to injector number one loses contact. Driving at night on 3 cylinders we got home but I had to miss work to fix it afterwards  :(
2nd trip it boiled on the M25. AA stuck it on a lorry and gave as a hire car to get home. Missed more work replacing the water pump but I am not convinced that I found the problem even though it hasn't done it since.
3rd trip had us limping along with a CV joint shaking violently whenever a sniff of throttle was applied. 7 hour journey with 2 screaming toddlers and a car that I don't have faith in was not a nice combination. :(
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #16476 on: 22 June 2018, 10:08:44 »
If it goes into limp occasionally you'll know the cause,I bought my 5 series as a scrapper as previous owner had fitted loads of new parts which were crap,namely crank and maff sensors,it actually ran better with maff disconnected until I fitted a good one :y
other rides
« Reply #16477 on: 22 June 2018, 20:49:40 »
Buggered it again.
Actually, I didn't break it, I found it broken, I suspect by the expensive "specialist" who last worked on it :(
« Reply #16478 on: 22 June 2018, 21:08:02 »
Collected some service bits from Mercedes and had them price up the clutch pedal components in order to replace all the worn out plastic bits on the current one... Pedal still sticks down occasionally so clearly the pivot and pedal return parts are past their best.
Came to a reasonable £31 including the pedal itself... :D so promptly ordered them.
« Reply #16479 on: 22 June 2018, 21:15:53 »
Ignoring the problem of the fact the cars are crap, their dealer parts prices I've always found more than reasonable normally.
Viral_Jim
  • Online Online
  • Telford
    • Too many, mostly broken
« Reply #16480 on: 22 June 2018, 23:06:32 »
Buggered it again.
Well if you will give it to other people....  ::)
What ails it this time?
« Reply #16481 on: 23 June 2018, 01:46:44 »
I've got the original and a couple of screwdrivers tucked away in the boot just in case Henry.  So far so good though, I've done lots of running around today and driven 125 miles home from South Wales and all good so far!  :y
« Reply #16482 on: 23 June 2018, 08:46:46 »
Buggered it again.
I didn't give it to someone else to do this, it was done by previous owner. Well, the Jag Specialist he used. Only jobs I've shipped out to "professionals" in recent times is tyres and that wheel bearing that I really felt was beyond me partly due to lack of tools.
I distrust garages too much to do most jobs, and there is only one way of knowing its done right ;)
Occasionally, I do have to ask for the help of grown ups from OOF members and ex-members :y
Its simply a split dust cover on the calliper piston. But they are not available from dealer, and the docs clearly state when that happens, the whole calliper has to be replaced :(
« Reply #16483 on: 23 June 2018, 09:14:27 »
As there are plenty of exchange ones available, repair kits must be available.  And a colleague you used to work in the trade has just identified one :y
£10 is cheaper than £280 ;D
« Reply #16484 on: 23 June 2018, 10:50:40 »
You seem to be having a lot of trouble with your Jag TB?  ???  :-\
