Author Topic: So what have you done to your car today?  (Read 8504127 times)
0 Members and 31 Guests are viewing this topic.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #1665 on: 01 February 2012, 08:47:32 »
Re-done the rear wheel bearing and while I was there I refurbed the adjuster bars in rear suspension (can't remember what they really are called in english  :P ). Almost done now, still have the headlight adjusters to sort and then my car will be better than it was when it left Rüsselheim  :D
« Reply #1666 on: 01 February 2012, 19:33:55 »
Oil & filter change!  :)  Helluva battle to get the filter housing cap off!!  :o  What monkey did that up??  ??? ::)
Oil leaking down the back of the motor, so cam cover gaskets and breather clean next job!!  :( :'(
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #1667 on: 01 February 2012, 19:36:16 »
half cleaned the inside
TC and BnQ Trade holder.
« Reply #1668 on: 01 February 2012, 19:36:29 »
Today I've refitted headlights, repaired wiring to both horns, refitted bumper and associated trim.
Now laying in bath trying to get my body temp back up...
« Reply #1669 on: 01 February 2012, 19:39:48 »
definitely the most effective method :y
« Reply #1670 on: 01 February 2012, 19:54:22 »
Removed the power sounder. Constant siren every 30 seconds after start up. Removed it. Still constant siren every 30 seconds. I know it has its own battery but this always amuses me. Wrapped it in a towel and shut it in a box in cupboard at the back of the garage, just like the last one. ;D
It's probably still bleating away now. ;D
Which reminds me. I did notice a melted area in the frost on the windscreen last week. But it was right above where the harmon uphill Kardon screen sits on the dash, so I assumed it was residual heat from that. Seemed to far up the screen to be ps causing it.... :-\
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #1671 on: 01 February 2012, 20:04:10 »
only if he remembers to put hot water in it as well   !!!   ::)
« Reply #1672 on: 01 February 2012, 20:16:14 »
Can't remember if I pulled the PS out of TBE when I did the LPG...
...suppose I'll have to through the tech2 on it to check, too cold to get mans tools out ::)
« Reply #1673 on: 01 February 2012, 20:17:06 »
One lot emptied, just filling back up again. Warmth!!
tgm147
  • Wirral
    • '02 2.2 Omega CD
« Reply #1674 on: 01 February 2012, 21:45:08 »
I've thrown it at a garage to do a head skim and replace the head gasket, fit new head bolts etc. Seriously considering getting rid of it now.
« Reply #1675 on: 01 February 2012, 22:29:41 »
I don't remember doing anything with it when we did your LPG either. ;)
Zippy2012
  • Worcester uk
    • 99,3.0 MV6 Est Ex Police
« Reply #1676 on: 02 February 2012, 03:14:05 »
Got in just before 6pm, nice little package from Jimbob on the mat.
Soooo, couldn't put it off longer.  Bumper off, headlights out, break me its cold - bumper sprang against my finger, so cold, it hurt like hell.  Spent about 10m investigating the other failure item, hmmm, need to scrath my bonce on that, are review the schematics again.
Bring the headlights inside to the warm, remove all the 'furniture' on the headlights, pop 'em in the oven, strip them down, replace the adjusters, rebuild.  Will refit tomorrow I think, if I get home at a sensible time.
Job I wasn't looking forward too, not so bad once you get stuck in.
What temp u set oven at to get lenses off??? & for how long?? do u need to add any salt & pepper or taste better without  ;D
all in the maint guide :y  check the index at the top of that section, or in my sig :y
ahh mate u could of just said the temp now i gota fathum out this site & where to find info... as im crap on computers...
k i have a look try find wat a sig is??....
« Reply #1677 on: 02 February 2012, 09:24:38 »
Want me to order some new batteries?
« Reply #1678 on: 02 February 2012, 09:36:29 »
Er yeah if you don't mind Kev.  :) Although I better cut the old one open first to see if the circuit board is damaged...?
« Reply #1679 on: 02 February 2012, 09:54:13 »
I was just about to order some leccy bits anyway.. Pop over with it sometime if you like. :y
