Author Topic: So what have you done to your car today?  (Read 6890476 times)
0 Members and 67 Guests are viewing this topic.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #16785 on: 05 August 2018, 07:34:19 »
Basically you don't "swing" both hammers.You hold one hammer at one side of the joint and hit the other side of the joint with the other hammer.
2boxerdogs
« Reply #16786 on: 05 August 2018, 15:02:21 »
Oil & filter change on the Hyundai , nice simple job & surprisingly cool laying under it !
BazaJT
« Reply #16787 on: 05 August 2018, 21:04:27 »
Backed it out of the garage and left it running while I cleaned garage floor then put it back in garage.Rear fan kicked in/out twice front fans did nothing even after turning heater controls to auto and setting both temp settings to Lo.
« Reply #16788 on: 05 August 2018, 22:22:53 »
Was the aircon working or was it set to Eco :-\
BazaJT
« Reply #16789 on: 06 August 2018, 07:38:23 »
Just seen this after replying in other thread DG,but to answer here as well I tried it with eco showing on the display[it was already set on that] and then without eco showing,made no difference to the fans.If they're not working due to lack of gas then fair enough,but if they're supposed to work regardless then obviously I have some other problem to sort.
« Reply #16790 on: 06 August 2018, 07:47:09 »
Over to other thread and report back  :y
« Reply #16791 on: 06 August 2018, 09:22:18 »
Drove it up North, to the land that used to be full of the Jockular Omega Club
Around Loch Lommond is stunningly beautiful. Then drove it further North.
Smashed one drone to pieces, nearly lost another in a Loch when it’s gyros had a spaz. Could be an expensive trip ;D
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #16792 on: 06 August 2018, 09:49:59 »
Which way did you go? You could call in for a brew on your way back down...!
« Reply #16793 on: 06 August 2018, 10:37:37 »
M6, not A1
annihilator
  • Wirral
    • Omega Tourer V6
« Reply #16794 on: 09 August 2018, 11:46:54 »
Drove the elite out into the sun for the first time in over 2 years from it's storage in my aunt's garage up to mine.Only a short journey but it seems to have suffered no ill effects just a large coating of dust.
John.
« Reply #16795 on: 09 August 2018, 11:59:17 »
Updated the software on the NLI
« Reply #16796 on: 09 August 2018, 14:52:17 »
Oil change on my elite with Fully Synth.
Not had one since 202,000 miles, it’s now on 221,996.
Still crying out for a cambelt kit, overdue on time and miles
Must do better  :-[
« Reply #16797 on: 09 August 2018, 15:24:03 »
What you need to do is update the software on my screen and everything hanging off the MOST, so I can update the bloody Satnav map ;D ;D
    • 530D M Sport, 330i Coupe
« Reply #16798 on: 09 August 2018, 18:09:04 »
Spark plugs and coil packs on the daily.  :y
« Reply #16799 on: 10 August 2018, 09:57:10 »
I have the power.......but possibly not the software old enough for yours (guessing its not pathfinder). pus our engineering tools are 'unlocked'.....
Page created in 0.023 seconds with 20 queries.
