Author Topic: So what have you done to your car today?  (Read 6911261 times)
0 Members and 15 Guests are viewing this topic.
« Reply #17295 on: 14 November 2018, 18:25:57 »
Of course you can. What could possibly go wrong, Zebedee?  ;D
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #17296 on: 14 November 2018, 20:22:15 »
Boingggggg :D
« Reply #17297 on: 14 November 2018, 21:31:21 »
They're potentially the same, but your link doesn't give spring dimensions.
Save the six quid and buy the ones I linked to :y Decent seller, have used for several items over the years  :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #17298 on: 14 November 2018, 21:40:59 »
looking at both, the £65 ones are "Coil Spring With Constant Wire Diameter" the cheaper are wit pigtail ends ,as per carlton (which snap ,and is a fail mot wise)
the same problem with astra G estate , the newer "Coil Spring With Constant Wire Diameter"  don't loose the pigtails
plus the postage is quicker on the £65 ones  ;D
But thanks for your input DG  :)
« Reply #17299 on: 14 November 2018, 21:46:33 »
All Omega rear springs have pigtails. Accept and move on  :y
That's to say that the ends of the springs reduce to a 2" loop. Spring wire thickness is 15mm for the entire length :y
« Last Edit: 14 November 2018, 21:51:57 by Doctor Gollum »
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #17300 on: 14 November 2018, 21:49:23 »
Swore at it...
51,000 trouble free miles in 18months and it waits till I'm living in a burger van, with access to 10% of my tools and then the o/s rear brake seizes. B!tch.
Still, I shall not be defeated. Just about to order everything I can think of and then borrow my mates drive. "working from home" on Friday I suspect.  ::)
« Reply #17301 on: 16 November 2018, 13:10:19 »
Broken it...
Went to got out, remote didn't unlock it, so unlocked with the key... promptly setting the alarm off as I opened the door. Key in the ignition and nada. Battery voltage a whole 7.8 volts ::)
Battery currently on charge, but car has only been sat since Wednesday lunchtime, so suspect battery is toast... Will run KW's excellent test guide to rule out alternator ;)
« Reply #17302 on: 16 November 2018, 15:45:11 »
Well, at 14.35v (dropped to 13.8v briefly with everything switched on before coming back up to 14.25v) at idle, the alternator is clearly ok.
Don't believe that I had left anything switched on, so have acquired a new battery to prevent any further issues.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #17303 on: 16 November 2018, 16:25:26 »
You ought to spend £20 on a drop tester....
« Reply #17304 on: 16 November 2018, 16:28:24 »
Worth checking if there's any significant current draw when parked up too. Last time this happened to me the heated rear windscreen relay contacts had welded themselves closed.
« Reply #17305 on: 16 November 2018, 17:35:50 »
I've had one of those in my Amazon wish-list for a couple of years.. I, too, should invest, given the BMW has taken a liking to discharging itself swiftly.
« Reply #17306 on: 16 November 2018, 17:54:55 »
Any recommendations for a drop tester, what with xmas coming....
  • Chatham, Kent
« Reply #17307 on: 16 November 2018, 18:12:14 »
It doesn't need to be anything special as you're only using it as an indicator, so a cheapy will do: LINK which is the first one listed on Ebay
I carried one like that(they all seem to be the same) in the truck until I wanted one that took up a lot less space. Sealey's BT102 is what I replaced it with, and still have. I vaguely recall it was about £50, but I velcroed it to my jump pack and used it daily
« Last Edit: 16 November 2018, 18:20:36 by Nick W »
« Reply #17308 on: 16 November 2018, 18:19:15 »
I carried one like that(they all seem to be the same) in the truck until I wanted that took up a lot less space. Sealey's BT102 is what I replaced it with, and still have. I vaguely recall it was about £50, but I velcroed it to my jump pack and used it daily
Thanks.  Wasn't ever sure if the cheapies were up to the job. I guess all those £15 type ones that look like your link are all from the same chinky factory, and are much of a muchness?
Cheers
« Reply #17309 on: 16 November 2018, 19:01:02 »
Settles down to a smidge under 0.2 MPs doors locked/alarm set/display off.
Unlock it and it spikes before settling at 0.35 with the interior lights (all led) on.
Ignition on, doors closed and it's around 1.15.
