Author Topic: So what have you done to your car today?  (Read 6916793 times)
0 Members and 20 Guests are viewing this topic.
  • Auckland
    • Mazda MPV
« Reply #17625 on: 13 January 2019, 16:11:24 »
Chimneys tomorrow then, or perhaps down a tin mine. :D
Maybe...........
In this part of Cornwall they mined copper first. Then arsenic. What could possibly go wrong?
« Last Edit: 13 January 2019, 16:13:03 by Andy H »
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #17626 on: 13 January 2019, 16:20:39 »
Wouldn,t have thought those two were in their late teens would ya. . :o  No offence mate, just my gallows humour, :-[
  • Online Online
« Reply #17627 on: 13 January 2019, 16:54:08 »
Maybe...........
Looks like you need to get up the ladder to finish pointing the chimney Andy.  ::)
Or is that a job for the girls too?  ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #17628 on: 13 January 2019, 17:04:50 »
Working at Height Regulations 2005 (WAHR)  ::)
you need to get the child labour some scaffold  :y
probably worth the investment ,they clearly can't reach the omega roof  ;D
« Reply #17629 on: 13 January 2019, 17:22:00 »
Why do you think the car was moved?  :D
  • Online Online
« Reply #17630 on: 13 January 2019, 18:42:06 »
The regulations only apply to adult workers, and then only barely in Cornwall!  :D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #17631 on: 13 January 2019, 19:27:50 »
WAHR does not refer to the height on a map of the UK  ::)
it's height from the floor  :y
Today I glued the bits together to make an offside wing mirror for Mrs Builder's car ;D
the "Bus Manager" has not rang me back as promised  >:(
which is nearly as annoying as people ringing who I was not expecting a call from  :-X
« Reply #17632 on: 14 January 2019, 17:21:54 »
Took a look at TBE's headlight washers - I thought I'd pulled the fuse, but that looks to be there, so lost interest.
« Reply #17633 on: 14 January 2019, 17:54:47 »
Drove it to first day at new job. And back.
Then fitted some chavvy light bulbs, that arrived today, to the interior lamps :D
« Reply #17634 on: 14 January 2019, 18:12:11 »
Chavtastic!
« Reply #17635 on: 14 January 2019, 18:21:54 »
Chavtastic!
Indeed, although they're Cool White because I couldn't get Burberry ones :D
    • 530D M Sport, 330i Coupe
« Reply #17636 on: 14 January 2019, 19:44:17 »
Left it a Serek's as its gone incontinent  ::)
neil74
  • newport
    • 2.6 elite estate.
« Reply #17637 on: 14 January 2019, 19:51:37 »
Mine also leaks oil and coolant everywhere. but as it was filthy I took it to the foreigners to get it washed and waxed.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #17638 on: 14 January 2019, 23:12:22 »
Just (hopefully) cured an oil leak on a Chinese motorbike with a smear of GM cam cover goo all around the gasket on the engine side casing before bolting it back on nice and tight.
Does that count, as GM products were involved ?  ;D
addy
  • County Durham.  UK
    • 2.6 CD Saloon 2ltr omega
« Reply #17639 on: 15 January 2019, 20:10:37 »
Been  having fun, cleaning valve lifters from wifes 2ltr omega. Headgasket went, so had head checked. Almost back together, just valves, cams, waterpump and timing to do, drain mayo out of sump.  ::)
What greeted me when piston removed
Piston parts laid out in their positions for assembly
Just got to pump them in oil to remove air.
Drives 1995 2.0ltr CD Estate.  2002 2.6 CD saloon
