Author Topic: So what have you done to your car today?  (Read 6912686 times)
0 Members and 18 Guests are viewing this topic.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #17970 on: 27 February 2019, 16:34:01 »
Handbrake shoes on the 190. Fiddly little job, similar to the Omega.
Worst part came at the start when I jacked the car up. The jack disappeared up into the floor as the rusty metal crumbled under the weight.
MOT runs out in two weeks, so need to get the welder out soon.  ::)
« Reply #17971 on: 27 February 2019, 16:38:26 »
Is he local?  ;D
« Reply #17972 on: 27 February 2019, 16:38:40 »
On a German car?......surely not. :)
« Reply #17973 on: 27 February 2019, 17:21:03 »
Serviced the Trolley... 180,720 miles...
Not bad for a city car :D
Migv6 le Frog Fan
« Reply #17974 on: 27 February 2019, 18:08:17 »
Well, it is 29 years old with 244000 on the clock. I have already welded up the other three jacking points, so this one must have been feeling left out.  ::)
« Reply #17975 on: 27 February 2019, 18:16:15 »
Almost exactly the distance to the moon. :y
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #17976 on: 27 February 2019, 21:11:30 »
Had to use aircon in 3.2 as it was quite warm today, surprised it still worked properly and blew chilled air.  :o
I do leave it in auto all the time, but most years it stops working at some point over Christmas.
You do realise that auto is a climate control setting and has absolutely zero bearing on whether the aircon* compressor is either working or engaged ???
*Aircon being a separate system which happens to have a single control button,(ECO), on the climate control panel ;)
On auto, air-conditioning compressor will be working, as it drys the air, if you press Eco compressor will be off(no air con)   think what tunnie means is he turned the temp down, climate then blew cold to adjust cabin temp to lower settings..
Hoof'land storeman.
« Reply #17977 on: 27 February 2019, 21:14:25 »
Perhaps but Auto still works with Eco pressed, just doesn't cool the air below ambient temp ;)
« Reply #17978 on: 27 February 2019, 23:01:46 »
I wonder how many modern Mercs will reach that age? ;D
Mate of mine had one the same age as my Omega which went to mr. Beanz about 10 years ago. Had been through a couple of sets of front wings by that time too. :-X
    • 530D M Sport, 330i Coupe
« Reply #17979 on: 01 March 2019, 07:26:32 »
Nothing.... Except get Serek and SOS to do a weld repair on one Omega and a Cambelt kit, Aux belt and Waterpump on the Astra.  :)  :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #17980 on: 01 March 2019, 19:14:50 »
Finished the MOT prep on the zafira tractor juice edition ,
MOT Tuesday
« Reply #17981 on: 02 March 2019, 17:27:07 »
5W30 Dexos2 oil and filter change on the Astra.
... it definitely needed it!
« Reply #17982 on: 02 March 2019, 17:52:45 »
More astras on here than omegas. AOF anyone?  ;D
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #17983 on: 02 March 2019, 18:02:22 »
Perhaps a name change to FOOF is in order?
« Reply #17984 on: 02 March 2019, 18:05:23 »
Go on, I'll ask. FOOF, Nick?  ::)
