Author Topic: So what have you done to your car today?  (Read 7070169 times)
0 Members and 29 Guests are viewing this topic.
« Reply #18165 on: 02 April 2019, 18:55:37 »
Dodgy links on the Internet giving me a stiff knob? Who'd of thought it.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18166 on: 02 April 2019, 19:02:52 »
NO no no
it's "Dodgy links" that's making your knob floppy  :P
the interweb links I posted are for your favourite internet auction site  :y
  • Auckland
    • Mazda MPV
« Reply #18167 on: 02 April 2019, 19:22:55 »
So for MigV6's benefit, its a Monaro.
Not one of these
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #18168 on: 02 April 2019, 19:28:57 »
Thanks.  :y...………..although I found out a couple of hours ago when I asked my manager. He is an ABS man, knows Keith, and had a "V8 Omega coupe" when he first started here, so knew what a CV8 was.  :D
« Reply #18169 on: 03 April 2019, 12:18:44 »
Not one of these
If it's good enough for The Baron..... :y
https://youtu.be/eP_l6dnoYlM
« Last Edit: 03 April 2019, 12:20:15 by Field Marshal Dr. Opti »
« Reply #18170 on: 06 April 2019, 19:16:36 »
Today, I've been playing a lot with my floppy knob, and now its a lot stiffer.
Many thanks to dave the builder for his links on how to make my knob less floppy.
« Reply #18171 on: 06 April 2019, 19:18:25 »
I've not put the trim back in yet, as the light is starting to fade, and the centre console in particular needs a bloody good clean!
2boxerdogs
« Reply #18172 on: 06 April 2019, 19:21:37 »
Filled all 3 of them with fuel, plenty of Nectar points !
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18173 on: 06 April 2019, 19:30:52 »
:o  :-X
Well done
does it slide in better now  :-\
you still need to think about lubrication  ;D
and if you get TC oil at £25 a tub ,no excuse not too  ;D
« Reply #18174 on: 06 April 2019, 20:07:08 »
:o  :-X
Well done
and if you get Tiger Balm at £25 a gallon ,no excuse not too  ;D
New POD
  • Miseryside
    • NEED MV6
« Reply #18175 on: 06 April 2019, 20:50:43 »
I should just have set fire to my MV6 instead of trying to fix it.
I was replacing a Rocker gasket, and to get more room I decided to take off the plastic scuttle, and to do this I had to take off the wiper arms, and to do this I had to pull them.
And suddenly I'm missing half of one of my front teeth.
Pictures Here
http://autoshite.com/topic/31221-vaxals-are-shite-part-6-go-to-page-7/?p=1787288
New oil seal on the crank sensor went on later and it currently doesn't seem to be leaking oil anywhere.
« Reply #18176 on: 06 April 2019, 20:59:56 »
At risk of seeming unsympathetic...
 ;D ;D ;D ;D ;D ;D ;D ;D
That'll learn you for removing half the engine bay... I bet you even undid the fuel lines  ::)
There's 40 bolts, two plugs, and three/four hose clips to undo and refit in order to do that job, and not one of them requires anything more than the bonnet to be open...
« Last Edit: 06 April 2019, 21:11:02 by Doctor Gollum »
« Reply #18177 on: 06 April 2019, 21:15:59 »
Are they genuine or pattern teeth? Shouldn't break that easily.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #18178 on: 06 April 2019, 21:28:16 »
Why can't I buy genuine Vauxhall toothpaste at TC prices over the counter?
Why????????
« Reply #18179 on: 06 April 2019, 21:34:19 »
Why????????
Just because.
