Author Topic: So what have you done to your car today?  (Read 6921498 times)
0 Members and 49 Guests are viewing this topic.
« Reply #18210 on: 12 April 2019, 17:04:38 »
Alot more space inside, especially being the long wheelbase one :y
3.6 - 3.8 metres long ;)
Boot is probably a similar size...
« Reply #18211 on: 12 April 2019, 17:20:17 »
Fitted some new LPG injectors.
Like for like or summat different  :-\
Same as it started off with - a pair of Valtek type 30s. Sub-£30 for a 3 pot rail. Should pay for themselves in a couple of tanks.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #18212 on: 12 April 2019, 17:29:06 »
Scrounged the use of a Hydragas pump, and pumped up the Metro. Which confirmed my suspicion that the kid I bought it off had fitted individualising valves and not pressurised the displacers! A few pumps on each corner brought it up 30mm all round and now the suspension works, although the back is bit firm. Other advantages are that the overly wide rear wheels don't look so silly, it has some ground clearance and it no longer looks broken.
I'll polish it at the weekend ready for the Dockyard show at Easter.
« Reply #18213 on: 12 April 2019, 17:31:34 »
Can't really argue with that  8)
« Reply #18214 on: 13 April 2019, 10:36:31 »
Anyway, the real startling point here is this.....
I like it
TB's first ever admission that he likes a Facelift Omega, anytime soon he'll be saying how much he likes the soft touch buttons and switches and the fact they don't rust....
Obviously I liked the MFL more. The MFL was the pinnacle, before the bean counters took charge.
But its cheap to fuel (when fuel is available), cheap to tax for its size/power, cheap to insure, and chavved up, looks good and different. Its just about quick enough, its supremely comfortable. Whats not to like.
Oh, and the interior mirror is on the memory, and it sets the clock itself. Unlike the stupid Jag.
But all Omegas rust like a bastard :(
neil74
  • newport
    • 2.6 elite estate.
« Reply #18215 on: 13 April 2019, 16:04:00 »
Changed the oil and filter and smashed my thumb on the idler. and then opened the glovebox and had the handle fall off completely and now I cant even close the thing..
    • 530D M Sport, 330i Coupe
« Reply #18216 on: 13 April 2019, 16:25:28 »
I like it
It's the age old problem, what do you replace them with if you want something that has all the good attributes of a V6 Omega but about 5 - 8 years old and under £8K.
« Reply #18217 on: 13 April 2019, 17:43:24 »
We've had all this before.....there really isn't anything. It's the same with BMW's of the same era. They were brilliant cars, but modern ones aren't the same.
« Reply #18218 on: 13 April 2019, 18:12:51 »
Low spec 2011 XFs are starting to fall into that bracket, but in your case, check the boot size. Trouble with other rwd marques from that era, base spec means poverty.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #18219 on: 13 April 2019, 18:19:21 »
Washed it, took some photos, and put it for sale on Gumtree,, now let's wait for all the scammers, and eejits ringing up, that's my fun for the week sorted... ;D
Not telling what's replaced it yet, it's petrol, and has a turbo,   :)
Hoof'land storeman.
« Reply #18220 on: 13 April 2019, 19:05:37 »
Yes looked at a couple of XF's, no good for me as boot is far to small and access to it is too narrow, plus I wasn't overly convinced by the handling (that said the vehicles I tested were 5 years old so not the freshest of suspension).
Low spec... No thanks.
« Reply #18221 on: 13 April 2019, 19:55:11 »
V70 T6 :D
biggriffin
« Reply #18222 on: 13 April 2019, 19:57:58 »
V70 T6 :D
Er no.
Hoof'land storeman.
« Reply #18223 on: 13 April 2019, 20:08:49 »
1.6 Astra :D
Olympia5776
  • Ireland
« Reply #18224 on: 13 April 2019, 20:09:14 »
Well after the Omega cruising through it's annual test a couple weeks ago once home and in the garage I noticed a large pool of coolent under it .
tcalss HBV sprung a leak . € 30 from main dealer seen a new one on the work bench.
On the x20xev the access space is , mmmm, challenged and after trying pliers , mole grips and the correct hose clip pliers I gave up ,ordered and got the remote extension version.
https://www.ebay.co.uk/itm/BlueSpot-Flexible-Long-Reach-Locking-Hose-Clip-Clamp-Pliers-Removal-Remover/222992153486?epid=1964514964&hash=item33eb5e3b8e:g:O7AAAOSw1nRbCCvI&redirect=mobile
This did the job in minutes.
Filled up the cooling system and noticed some beads of water under bottom hose .
Radiator goosed......leaking from core at bottom under bottom hose. Ho hum !
Decided to buy locally instead on line in case of damage in transit. Had to buy one equipped with trans oil cooler asall seem to be sold that way.
Took opportunity to tidy up wiring insulation with fabric tape , derusted, painted and waxoyled first time exposed areas in 17 years ownership using my new Lidl waxoyl gun ( which at € 8 is an absolute gem ) .
All reassembled and tested ,fan coming in at 90 c , no leaks , happy chappy. :y
