Author Topic: So what have you done to your car today?  (Read 6912230 times)
0 Members and 18 Guests are viewing this topic.
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #18855 on: 29 July 2019, 07:59:46 »
While in general I have no problem buying stuff from ECP I'm not sure I'd trust them on this one[obviously your choice to do so or not]I believe there is an equivalent fluid available from Mitsubishi for less money than the "proper" Volvo fluid.Other sources may then be cheaper still.The important bit is to do partial changes to allow fresher fluid to refresh seals and generally clean the gearbox gently rather than change all the fluid in one go.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #18856 on: 30 July 2019, 18:08:15 »
Nothing, but I sold the mighty Honda chicken chaser for an obscene profit.  :)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18857 on: 30 July 2019, 18:11:20 »
well done  :)
so , thee old Honda's are an appreciating asset
just like Omegas  ;D  :-X
Migv6 le Frog Fan
« Reply #18858 on: 30 July 2019, 21:15:27 »
Running and maintenance costs are a wee bit lower though.  :)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18859 on: 30 July 2019, 21:33:52 »
A trade off that reflects in the "comfort level" though
the omega does not have a lockable loop for the crash helmet
but the omega has a few toys the C90 doesn't  ;D
« Reply #18860 on: 30 July 2019, 21:48:04 »
Three spare wheels and a touch more power  ;D
« Reply #18861 on: 01 August 2019, 18:01:20 »
Plugged into the LPG ECU, as she said it kept erroring this morning, a few miles into her journey.
Only faultcodes were batt voltage errors, probably from when the battery failed a few weeks back.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #18862 on: 01 August 2019, 20:03:00 »
Fitted new front and rear pads to the Saab today,swapped wheels front to rear at same time to try and even up the wear a bit,it likes front tyres so they'll never perish ::) :-\
other rides
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18863 on: 01 August 2019, 20:22:38 »
FWD  :-X
Just drive like a girl if you want the front tyres to last  ;)   :D
henryd
  • west cornwall
« Reply #18864 on: 02 August 2019, 12:30:54 »
FWD  :-X
Nah,thats boring,its the mid range grunt thats really good and that probably does for the tyres :-X
other rides
« Reply #18865 on: 02 August 2019, 17:44:42 »
Took TBE for a drive yesterday evening. Yup, the LPG is definitely playing up, with a weird fault.
Its either the pressure sensor
Fault solenoid or associated wiring, as it was about 3 months ago
A blockage, less likely, as when it works, its perfect.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #18866 on: 05 August 2019, 16:52:56 »
Wired in the dashcam mounting kit to allow me to swap the unit from car to car. Unfortunately, after removing the overhead panel, I discovered that the sunroof indicator light had melted into its plastic surround, hence ad in the wanted section. :( :( :(
« Reply #18867 on: 05 August 2019, 18:35:54 »
TBE's LPG just fixed itself when I went to investigate the fault. Hmmmm.
Changed the oil on the XJ on Saturday, before having to test the anchors on Sunday when some silly bint stepped into the road when a 70mph 1.8t car was almost upon her.
Migv6 le Frog Fan
« Reply #18868 on: 05 August 2019, 19:17:49 »
Got an offer for the old 190, which is £100 more than I paid for it about 6 years ago. Not bad considering its a non runner. ;D
Then went out and bought a Re****t.  :-[ :-[ :-[
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18869 on: 05 August 2019, 19:21:17 »
Reliant  :)
Renault  :o :-X
