Author Topic: So what have you done to your car today?  (Read 7600416 times)
0 Members and 26 Guests are viewing this topic.
« Reply #18990 on: 30 August 2019, 18:29:29 »
New windscreen on the V70.  :y
And the auto wipers? Throw a bucket of water over it and report back.  ;D
  • Online Online
« Reply #18991 on: 31 August 2019, 16:12:03 »
Oil and filter change on the Zafira, along with new pollen filter and air filter.
Still can’t find coolant leak on 3.2, strangely it only ever leaks on way back from work.  :-\
  • Online Online
« Reply #18992 on: 31 August 2019, 16:39:58 »
Had to perform some gynecology on the V70 to replace a brake light bulb.  ::)
What a bloody faff!  >:(   :o  :D
The intermittent wipers are working nicely now though!  :y
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #18993 on: 31 August 2019, 19:46:16 »
Washed the Omega, hoovered the interior and changed a number plate bulb, then "improved" as opposed to fixed, the dented rear hatch on the Welsh C**o.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #18994 on: 31 August 2019, 20:18:49 »
Washed the Omega, hoovered the interior and changed a number plate bulb, then "improved" as opposed to fixed, the dented rear hatch on the Welsh Cl-Eeyore .
nice to hear your still looking after the Omega even though you've got that shiny red race-car to play with  :y
did you use the correct 9151V french car adjustment tool to adjust the rear of the Cl-Eeyore  :-\
Migv6 le Frog Fan
« Reply #18995 on: 31 August 2019, 21:25:15 »
Wasn't enough space for that so had no choice but to use a smaller one.
« Reply #18996 on: 31 August 2019, 21:40:58 »
You've been bashing le tadpole? Bastard!  ;D
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #18997 on: 31 August 2019, 21:45:37 »
Can you not use a black light, or similar to find coolant leaks?
Viral_Jim
  • Telford
« Reply #18998 on: 31 August 2019, 22:13:13 »
As for me, I listed the TerribleCan on eBay, an so far, it's gaining me 99p.  ;D
  • Online Online
« Reply #18999 on: 31 August 2019, 22:29:03 »
Stuck some UV dye in it, had a look with special torch. Can’t see anything. Top it up and do ~25 miles to work it’s fine. Check at lunch when cooled, level still exactly where was when left home.
Drive home and it drops half cm or so according to header tank.  :-\
« Reply #19000 on: 31 August 2019, 23:21:38 »
I've never used u/v dyes and black torches .. far simpler way is two bottles of bright yellow food colouring added to system then run the car for a representative time such that the leak occurs ... you will then see a yellow "stain" at the point of leakage. Advantage of this method is that a small leak where the liquid evaporates quickly leaves a nice yellow stain that is easily visible... it has never failed me in over 40 years on numerous motors  :) .. it is also a VERY cheap diagnostic tool  :)
https://www.sainsburys.co.uk/webapp/wcs/stores/servlet/gb/groceries/dr-oetker-yellow-colour-gel-15g?storeId=10151&langId=44&krypto=9MyoELdR9epibnY0YeY9uXMaRDNe9yynaA52NHA2q3qCWNk4p6I%2B7sJVeoqyN%2By9VUNVb2452%2BlIYQzhSsfwj3hHKsVLyejy1HWfHXODSiy%2FllrgKUwn1Q7VEcmuGMmImjAFxMx%2BatI%2B%2BNIS7fM3CFmJEz5uW0xNo3vFJ%2FUTdIw%3D&ddkey=https%3Agb%2Fgroceries%2Fdr-oetker-yellow-colour-gel-15g
other makes are available ... I used to steal whatever Mrs E had in her baking store ......   :)
« Last Edit: 31 August 2019, 23:24:07 by Entwood »
  • Online Online
« Reply #19001 on: 01 September 2019, 00:00:06 »
You should convert it to an Essex Cl*o.  :y
It'll probably go faster!  ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #19002 on: 01 September 2019, 00:16:28 »
This^^^^^^>. It's cheap, works, and environmental friendly...
Hoof'land storeman.
Migv6 le Frog Fan
« Reply #19003 on: 01 September 2019, 08:10:24 »
I think Union flag on the front and one of those on the back. Cheers.
Migv6 le Frog Fan
« Reply #19004 on: 01 September 2019, 08:12:01 »
Swmbo insists on calling it Airfix one, so Im hoping to get some kind of sticker made with that on at some point.
Page created in 0.418 seconds with 20 queries.
