Author Topic: So what have you done to your car today?  (Read 8188223 times)
0 Members and 82 Guests are viewing this topic.
Migv6 le Frog Fan
  • Online Online
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #19635 on: 30 December 2019, 17:01:27 »
probably air in the lines now ,fully charge the battery and crank it several times ,unless there is provision to remove a pipe or sensor to bleed the lines .
tractors are a pig to get started up initially after getting air in the tractor juice lines
There is a primer bulb in the engine bay. I gave that a good pumping before starting it. Battery was low though, so its on charge now.
Working dayshift tomorrow, but asap will try again and maybe crack of the pipes to the injectors to bleed out the air.
In fact Im getting tempted to go out now with a torch and give it a try, as its driving me mad.
« Reply #19636 on: 30 December 2019, 17:32:19 »
Washed the Posh Vectra, and fitted some Osram nightbreaker+ as well :)
I'm contemplating some new bulbs for the Jag again.  But the £150 a pair is causing a certain amount of clenching ;D
   what bulbs are they then?
Really expensive ones ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19637 on: 30 December 2019, 17:34:40 »
having had to fix sh!treon picasso's for a family member for years I know the feeling
fortunately replaced with a Zafira A tractor now
the primer bowl won't let air out the HP lines ,
at least the ecu is happy and engine management has light has STFU  ;D
so it sounds like your very close to having a working French POS soon  :y
Migv6 le Frog Fan
  • Online Online
« Reply #19638 on: 30 December 2019, 18:04:41 »
If only. Tried cracking off the pipes and turning it over, then tightened them up and it did the same as before. Started on probably two, then cut out after a few seconds. Read the fault codes and I have a new one. P0201 - yes the injector open circuit has moved from number 4 to number 1.
Ffs, all things French are shite !
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19639 on: 30 December 2019, 18:17:57 »
have a rest , put allo allo on the telly box
 try tomorrow with a good battery and make sure all the plugs checked ,earth points sound etc
worth a jump lead from the negative of the battery to the block too from experience of French wiring  :-X
Migv6 le Frog Fan
  • Online Online
« Reply #19640 on: 30 December 2019, 18:28:33 »
The jump lead to the block might be worth a try. I should have thought of that myself. Working tomorrow so it will have to wait, but in the meantime I will get the battery fully charged.
Swan vestas are now on standby though. Fed up of spending £8 per day on petrol just to go to work and back.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19641 on: 30 December 2019, 18:41:58 »
8 quid will get me 30 miles in mine if i'm lucky  ;D  sub 24.5mpg  average
cheaper matches are available ,swan vestas are pricey
it's Christmas , apparently  ::) a shame you have to work ,
so treat yourself to driving to work in comfort in the Omega
don't stress out ,bills will still be there in January
Migv6 le Frog Fan
  • Online Online
« Reply #19642 on: 30 December 2019, 19:02:29 »
Im driving gently in mine and currently averaging 25.4 mpg on the 33mile return trip to work.
The only difference Christmas makes to me is having to work a lot more hours, but thats my fault. I should have attended school and listened a lot more when I was there.
Its very nice driving to / from work in the Omega, but every time I come home the little red pile of shite still sits on the drive taunting me.
The bills will indeed still be there and be joined by plenty of others.
I don't like giving up, but that box of swan vestas is calling to me, and it gets louder every day.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19643 on: 30 December 2019, 19:23:49 »
..... I come home the little red pile of shite still sits on the drive taunting me.
it senses your frustration and feeds off it ,don't let it ,ignore it for now ,then attack it with a fresh head (and a fresh battery)  :y
don't waste money on matches , it's french , leave it long enough and it will burn itself down  ;D
OK , i'd best STFU
probably not helping with my jokes  :-X
« Reply #19644 on: 30 December 2019, 20:55:21 »
Top gear's manufacturer of the year, 2019, is...........Renault 👏🏼👏🏼👏🏼😂
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #19645 on: 30 December 2019, 21:26:00 »
Just shows how much they know ::) Same with European Car of the Year award winners how many of those have actually been a success[Renault 9 anyone?] ??? ???
BazaJT
« Reply #19646 on: 30 December 2019, 21:34:37 »
Put a new ABS sensor on the o/s front of the V70 to douse the ABS light that came on the week before Christmas.All good again now :y
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #19647 on: 30 December 2019, 22:52:45 »
         Mm.. not cheap then :o I’ve bought some cheap D2S  bulbs for mine from power bulbs.. Ultra Gt had the about six weeks and are very good at least so far  :y
.  Of course if they are the same.
Laying a rubber road.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #19648 on: 31 December 2019, 07:49:11 »
 Went to work this morning,, and WOW what a difference,  I can see more.
As a side note ordered them from Amazon,  Sunday, they arrived yesterday,, is this because I don't have a Brackley post code.. ;D
Hoof'land storeman.
« Reply #19649 on: 31 December 2019, 14:34:17 »
D3S
Page created in 0.644 seconds with 20 queries.
