Author Topic: So what have you done to your car today?  (Read 7582124 times)
0 Members and 26 Guests are viewing this topic.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #19665 on: 01 January 2020, 13:37:43 »
Didn’t know that, simple but effective :)
it's unlikely to simple if BMW designed it. Or any German.
Indeed. Or effective.
it might be effective, but you have to read the manual of 32(not counting the legal disclaimers) closely typed pages for a device that ought to be operated with a lever marked open and closed.
On that theme:
a French design would be just as complicated, but full of flimsy parts that ought to be strong, and parts that could be flimsy made from girders. It wouldn't come with a manual
The English design would involve the lever mentioned above, but the open and closed labels would be stuck on the wrong ends. Crookedly.
The Italian mechanism would have fallen off on its first journey, so nobody knows what it looked like. Or needs a manual ;D
Etc, etc
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #19666 on: 01 January 2020, 13:58:55 »
Ahh, my moscky van had a lever to blank the radiator in the winter, great idea. ;D
 The British way was easier, put a bit of cardboard in front of radiator, then wonder why it keeps overheating in the spring ;D
Hoof'land storeman.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #19667 on: 01 January 2020, 14:05:29 »
Or silver foil ;D ;D
Laying a rubber road.
« Reply #19668 on: 01 January 2020, 15:39:21 »
On that theme:
Etc, etc
That neatly sums up the AMMs and of an A320  ;D
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #19669 on: 01 January 2020, 16:53:05 »
Had another play with airfix 1. Fully charged battery. Jump lead from battery negative to block - no change. Still showing p0201 as opposed to the previous p0204.
Swapped injectors from pot 1 and 4 over. Still shows p0201.
I think the thing to do now is to splash out £35  on a Renault-COM Bluetooth all the way from Manchester China and hope for the best.
I seriously doubt a wiring problem as it hasn't been disturbed at all, so now having thoughts of fried ECU.
I read today that Cherie Blair was on the board of Renault the same time as the bloke who arrived in Beirut in an instrument case the other day.
Had the seller of the Renault provided me with this info at the time, I would have run a mile. Might see a solicitor about this terrible lack of disclosure.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #19670 on: 01 January 2020, 16:54:58 »
Replaced the window/mirror door switch in Mrs. AA's Astra.
I like red cars
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19671 on: 01 January 2020, 17:16:38 »
have you tired using a low watt 12v bulb as a noid light to test the wiring ? and checked loom plugs and continuity  :-\
example clicky
Keith ABS
  • Maldon Essex
« Reply #19672 on: 01 January 2020, 17:32:25 »
 Woke the V8 from its winter slumber just to run it up on the drive, for thirty minutes. Roll on April or if we believe the Dail Express, June before the snow goes away
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #19673 on: 02 January 2020, 16:01:34 »
Filled the Range Rover up average 26mpg very happy with that 😎
« Reply #19674 on: 03 January 2020, 10:12:10 »
Got a years ticket on the Jaaaaag, no advisos :)
Not that I resolved the 2 advisos from last year  ::)
« Reply #19675 on: 03 January 2020, 10:13:13 »
Remind me, yours is a TDV6 RRS? Or TDV8?
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #19676 on: 03 January 2020, 10:50:57 »
TDV8 RRS I was advised to avoid the V6 too many problems.
« Reply #19677 on: 03 January 2020, 11:10:38 »
I think the TDV8 has just as many problems (turbos, EGRs etc), they just don't result in the crank snapping itself in half like the TD or SDV6 ;D I see lots of forum owners religiously buy a warranty every year "just in case" the engine (more than likely) eats itself.. I got a quote for a warranty on mine - £1500p/a! And people are paying that every single year, the risk of snapping a crank is seen as that high..
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #19678 on: 03 January 2020, 11:36:21 »
I just put £150 per month into a savings account for maintenance  so far put £600 in & spent £55 on a  new door actuator , it's called commonsense why put cash into other peoples pockets, if you have to worry about maintenance & running costs these are a prime example of a vehicle to avoid, however the TDV8 is in my opinion the one to have, I had a budget of £13,000 the purchase price of this was only £7000 so if any disastrous mechanical failures occur they will be dealt with, have found an excellent independent who has been all over this & the only fault that needs attention shortly is the EPB.
« Last Edit: 03 January 2020, 11:50:24 by Rangie »
« Reply #19679 on: 03 January 2020, 13:15:36 »
The two new wheel bearings in December see me up to £2,318.76 since September already.. £150pcm isn't going to cut it ;D
Page created in 0.038 seconds with 20 queries.
