Author Topic: So what have you done to your car today?  (Read 7428821 times)
0 Members and 55 Guests are viewing this topic.
    • 530D M Sport, 330i Coupe
« Reply #19800 on: 14 February 2020, 19:04:15 »
Drank coffee and ate a sausage baguette while Serek fitted wishbones (re-using the front poly bushes of course!). Cheers Serek  :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19801 on: 14 February 2020, 19:39:41 »
Fitted a cam belt kit and waterpump to another of the astra H fleet (no record of it being done ,100K )
the belt had been changed before ,but not the tensioner or idle pulley  ::)
bearings where very ropey ,not far off failing , i knew there was a bearing noise, thought it was the aux tensioner pulley ,that just needed re-packing with grease .
so ,even if you have a stamp or history that a belt has been changed , it may be just that ,the belt ,NOT the bearings,idler ,tensioner  :y
« Reply #19802 on: 14 February 2020, 19:49:43 »
VX have form for that...  :-X
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19803 on: 14 February 2020, 20:08:36 »
it was a gates belt ,GM part number ,so you could well be right DG  ::)
probably when it was sold to the second keeper
buyer says can you replace the cam belt to the dealer , so they do JUST that  :(
« Reply #19804 on: 15 February 2020, 10:24:30 »
Fitted a new temp sensor on the LPG system, but for speed it was a no-name one with no info. It measured 5k, so I set it as one of the 5k sensors supported by the (old, v7 I think ;D) Stag software.  Runs lumpy as frick until warmed up, and blows the trims right out, so she uses on it petrol until its fully warm, and then she manually switches over.
In the depths of time - 10yrs ago when fitted - I suspect I might have played with temperature compensation, so I need to have a look. But its phishing down, its windy, its cold, and most importantly, "its not my car"
Other than that, I've been stuck in a shitbox Corsa most of the week, but fortunately I was chauffeured everywhere. A revving little bugger, but needed another gear for long dual carraigeways.  Beats the last hire car we had, and god awful 69 plate Qasqai that crippled me for days afterwards.
« Reply #19805 on: 15 February 2020, 10:26:01 »
All franchise dealers do.  In fact, you'd be lucky if they even changed the belt.
« Reply #19806 on: 15 February 2020, 11:40:30 »
Mine's in for a cambelt on Wednesday. I made sure that the youth who booked it in wrote 'cambelt, tensioner, roller and water pump' in the book.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19807 on: 15 February 2020, 12:01:44 »
I'd ask for the old parts to be put in your boot Uncle Stemo
and check the invoice lists the parts or a part number that relates to a kit  :y
oh , and they stamp it in your service book
« Reply #19808 on: 15 February 2020, 12:21:08 »
It's a local independent garage that I trust, Dave. Not everyone is out to rip you off and this outfit have been doing my cars for about five years now. It's the one with spider man on the roof.  ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19809 on: 15 February 2020, 12:43:11 »
OK  :y
I thought you where taking it to a Vauxhall main stealer  :-[
so spiderman keeps an eye on them to make sure they don't rip you off  :o
what's he going to do ,shoot a sticky web at em if they don't replace all the parts  ;D :D
« Reply #19810 on: 15 February 2020, 12:55:42 »
OK  :y
There's got to be a certain amount of trust between any consumer and the tradespeople they employ. Even builders. I'll bet you've done jobs where the customer has parked their arse in a chair in the corner and watched you like a hawk all day. Not nice.
« Reply #19811 on: 15 February 2020, 12:58:50 »
The GM (Fiat) Diesel engine in not hard to do a cambelt on. Drivers side wheel and arch liner off. Engine mount off. Cam cover off. One roller, one tensioner and waterpump all within easy reach. On the YouTube vids, no locking kit is used.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19812 on: 15 February 2020, 16:04:56 »
yep , I just explain what i'm doing to them , if they keep me talking then it slows the job down  :(
indeed , most cam belts are simple to a competent spanner monkey
I think the only belt that is 'relatively complicated' is the V6 Omega one   ;D :D
« Reply #19813 on: 15 February 2020, 16:15:47 »
Front discs and pads on the daughters Corsa.
« Reply #19814 on: 19 February 2020, 15:30:45 »
Cambelt done, £383.32, not that cheap for an indie.  :-\
Page created in 0.023 seconds with 20 queries.
