Author Topic: So what have you done to your car today?  (Read 8492449 times)
Rangie and 24 Guests are viewing this topic.
Keith ABS
  • Maldon Essex
« Reply #19860 on: 01 March 2020, 16:06:29 »
 Finally got to wash the Zaf. Must be 10Kg lighter. The joys of living in a rural area
polilara
  • Finland
    • 2.6 Y26SE Elegance 2001
« Reply #19861 on: 01 March 2020, 16:44:46 »
Added oil and found mayonnaise in cap an hole, a lot. Perhaps Mobil 1 5W-50 not best possible choice.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #19862 on: 01 March 2020, 21:11:10 »
Fitted two new struts to the hatch after I smashed my head on it Thursday :-[ £10 from EB.. for the both delivered. Bargain.
Laying a rubber road.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19863 on: 02 March 2020, 08:54:51 »
SHHH !
You will make TB jealous ordering things from eBay and actually getting them delivered  and they work   ;D :D
you should have been wearing your hard hat and other PPE  ::)   :P    ;D
Raeturbo
  • South Wales
« Reply #19864 on: 02 March 2020, 10:23:55 »
 ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #19865 on: 02 March 2020, 17:32:41 »
 You've a compressor to fit soon ;)
Hoof'land storeman.
Raeturbo
  • South Wales
« Reply #19866 on: 02 March 2020, 22:08:41 »
You’re right there Trev but I’ve got someone to fit and gas it for me. They took 520 grams of fluid out of it while checking so at least I’ll get that back😂 Btw thanks for the express service😎😎
biggriffin
« Reply #19867 on: 03 March 2020, 11:00:55 »
 We aim to help, were we can,  :y
Hoof'land storeman.
« Reply #19868 on: 04 March 2020, 17:30:23 »
Do it from above ;)
Doh! Talk about a brainfart moment.  Helps if you go done in front of the radiator ;D
Thanks for the tip Al :y
Shame it appears it wasn't the sensor (unless the cheapo egay sensor is wank).  So it'll still be a bumper off job, poxy thing ;D
« Reply #19869 on: 04 March 2020, 17:31:48 »
Changed the temp sensor, and engine oil (but not filter :( - just too windy, was hard enough getting the oil from the sump into the container without it going everywhere).
Old oil was 7k old, and had gone quite dark, but sure I'll get away with not changing the filter this time.
Had a quick look at LPG, but the weather turned, so for now, just whacked the switch-over temp to 70C.  Suspect I might have to whack it up further, until I can find a solution (probably new injectors)
What injectors do you have on yours?
Badged Motogas, which I think was Teilo's brand - so god knows what they really are ;D
The Valteks that I had on the 3.0l were flawless, believe it or not.  In fact, they may go on as a test ;)
« Reply #19870 on: 04 March 2020, 17:34:13 »
SHHH !
Well, the last 2 sets of struts I bought for the Omega from Ebay, I'm still waiting for ;D  (actually, ATP did eventually refund after an awful lot of chasing (it might have actually been ebay/paypal that sorted it)).
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19871 on: 04 March 2020, 18:21:27 »
this week I checked over the 2003 Zafira A ,elegance ,tractor juice edition ,oil and filter change
stripped the brakes etc , checked and painted all brake lines etc ,replaced one track rod end ,2 new tyres
dropped it in for MOT
passed but with one advisory  ::)
 the other track rod end has slight play  ::)
it was very slight ,but replaced it anyway as i had some
so ,another years high performance luxury motoring  ;D
glad to get back in my Omega after driving the zafira  8)
456lbft
    • Omega MV6-Fred
« Reply #19872 on: 08 March 2020, 21:58:45 »
Cam belt change, is also the right time to investigate oil leaks, which are expected to be from the cam covers.
Once cam wheels were removed it was obvious that the leaks were mainly from the front cam seals.
Carlton 3.6 Track Car
Omega 3.2 MV6 Fred
neil74
  • newport
    • 2.6 elite estate.
« Reply #19873 on: 08 March 2020, 23:25:44 »
Changed the oil/filter on Friday. and replaced a few bulbs in the dash..
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #19874 on: 09 March 2020, 09:42:09 »
well done for looking properly, finding the problems and not just rushing through it  :y
