Author Topic: So what have you done to your car today?  (Read 8479073 times)
0 Members and 18 Guests are viewing this topic.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20085 on: 16 April 2020, 17:51:47 »
Why bother correcting the mileage?
so it's right
true mileage is 81--- not 36---
not that i'm selling it or anything but i want it right  ;)
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20086 on: 16 April 2020, 17:53:51 »
plus, if i'm still alive when the next MOT is due it will be wrong on the MOT database  :D
« Reply #20087 on: 16 April 2020, 18:00:36 »
They do allow for the changing of a speedometer. The system isn't as anal as you  ::)
As far as I know the only way to 'correct the mileage' is to remove the clock and force it round with a screwdriver  ;D
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #20088 on: 16 April 2020, 18:14:41 »
 You can dismantle the odometer,, bit fiddly, so practice on the old one first, you might be able to go old skool, and just use a drill to go backwards. :y
Hoof'land storeman.
« Reply #20089 on: 16 April 2020, 18:15:13 »
If it's on standard 225/55/16 tyres, then your computer will be spot on :y
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20090 on: 16 April 2020, 18:35:35 »
I know it can be up on the database WRONG  ;D
I want it to be right  ;)
Thanks , I'll try the code reader  :-X on the old clocks (i know i can change mileage on LCD digital clocks like astra) and if that fails I will follow your advice and take the old clocks apart as you suggest  :) then learning from that ,what parts snap off etc  ;D :D then TRY and do it right with the new clocks   :P
Thanks DG , I matched part number on clocks and being ex plod ,i assumed the code index would be OK
just wondered how long it takes to get average MPG data etc back (saving zero ,but not driven it yet) range is correct, idle MPG correct ,just no average consumption or trip distance
I didn't have my wallet in my pocket so the wallet thickness sensor in the driver seat may be confused  :P
« Reply #20091 on: 16 April 2020, 18:39:01 »
Get a fickin life  ;D
« Reply #20092 on: 16 April 2020, 18:48:49 »
Cant change the mileage on an Omega via a code reader.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20093 on: 16 April 2020, 18:49:50 »
where from Uncle Stemo ? got a link ?  ;D :D
« Reply #20094 on: 16 April 2020, 18:51:09 »
Not for at least three more weeks  :-X
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20095 on: 16 April 2020, 18:51:55 »
thanks Jamie , saves me time  :y
so it can't even be done with genuine Tech 2  :-\
« Reply #20096 on: 16 April 2020, 18:54:40 »
Nope. It's electromechanical rather than digital ;)
« Reply #20097 on: 16 April 2020, 18:57:01 »
It's a fickin ancient abacus.  ;D
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #20098 on: 16 April 2020, 19:14:34 »
Anyway...…...……………..what Ive done with my car today.
Started into the job of changing the donut bushes. As I thought it wasn't straightforward. Hell of a job to get the old one out. Most of the rubber came out with a bit of effort, but the metal cone fought hard to stay where it was.Seemed like it was bonded in place or something. Got the new one into the arm, but still about half an inch to go before it is fully home. Inserted bolt, but found it didn't line up with the hole. Much pushing and shoving before finally getting it lined up.
Have now tightened it and will leave it overnight hoping it will pull itself home in the meantime.
Would like to have got one side finished, but got called in for me tea.
Hopefully the second one will be a bit easier.
« Reply #20099 on: 16 April 2020, 19:16:27 »
Achey bod in the morning  ;D
