Author Topic: So what have you done to your car today?  (Read 7438649 times)
0 Members and 57 Guests are viewing this topic.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20130 on: 17 April 2020, 22:08:00 »
Whacked the donut bush in the last half inch and reassembled. Was planning on doing the other side but ended up driving down that London to deliver a food parcel to daughter. Return journey of 130 miles on near empty roads reminded me what a lovely old thing the Omega is to drive.
Got out fresh as a daisy with a smile on my face. Just what I needed at the moment.
Glad you got it in, there's another side too though  ;D  :-X
I love driving my Omega ,puts a smile on my face too  :y
It's probably the only car on the fleet still on full pay
all the other vauxhalls are on furlong pay
still taxed ,insured and MOTed but using no fuel  ;D
yes ,I should be using one of the astras for shopping and delivering etc because they use much less fuel  ::)
am I going too
er ...
NO   ;D
« Reply #20131 on: 17 April 2020, 22:33:24 »
Enjoy your omega while you can, Dave.
« Reply #20132 on: 17 April 2020, 22:34:58 »
Oh......and you might as well give me all of the money you're saving on fuel.  :)
  • Auckland
    • Mazda MPV
« Reply #20133 on: 18 April 2020, 08:47:22 »
SWMBO has been taking the Mazda a couple of miles every few days to get shopping or medication since lockdown started.
It only just managed to turn over this morning so I tucked it up in the garage with a drip feed of electricity to top up its (tiny) battery.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #20134 on: 18 April 2020, 12:18:25 »
Working days this weekend, so planning on doing the other donut bush Monday or Tues. if it stays dry.
Then need to start thinking about a service, plus cambelt, Aux. belt, remove sump to clean the strainer. It will never need working on again after Ive done that lot...……………………………
Shut up Stemo.
« Reply #20135 on: 18 April 2020, 12:56:45 »
Shut up Stemo.
 :-X :-X :-X
Migv6 le Frog Fan
« Reply #20136 on: 18 April 2020, 13:04:24 »
Thanks very much.
luizvivas
  • Belo Horizonte, MG, Brazil
  • 92/93 Toulon Green 1-5-3-6-2-4
    • Omega CD 3.0 Turbo
« Reply #20137 on: 19 April 2020, 15:08:30 »
Position lamps installed in turn signals.
Powered by C30NE
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #20138 on: 19 April 2020, 15:16:30 »
Waxed the Subaru, looks excellent a real good sparkle on the metallic silver , glass all cleaned as well oil change due in June & that's about it for the year.
Migv6 le Frog Fan
« Reply #20139 on: 19 April 2020, 15:25:58 »
Brought another Omega wheel to work for a refurb. I shall work my way through the four of them by the end of the month.
The futile quest for perfection helps pass the long shifts.
amba
  • Medway towns
    • German V6
« Reply #20140 on: 19 April 2020, 17:12:25 »
Sounds a nice little job you have there Albs...getting paid to refurb your own wheels
« Reply #20141 on: 19 April 2020, 17:42:42 »
Removed the offside rear door card on the Mondeo and gave the sticky door lock a squirt of WD.  Reassembled and all's good now!  :y
Migv6 le Frog Fan
« Reply #20142 on: 20 April 2020, 14:22:43 »
Shut up Stemo.
Should have kept my mouth shut. Fitted the other donut bush just now. Was a lot easier than the first and in a lot worse condition. The steel sleeve in the centre was completely detached from the rubber.
When I did the other side I did some cleaning up etc. around the various parts at the rear, including the annual ritual of removing surface rust from the  damper, and giving it a coat of paint, as I wanted to preserve the original self levellers.
When I finished fitting the bush today I noticed some oil on the drive at the other side of the car. Had a look and its running down the outer surface of the damper. Havent looked closely yet, but I think its likely that after cleaning it up this time, the metal has got too thin and its sprung a leak. Had to happen some time I suppose.
Shame, because I wanted to retain the self levelling and keep the old girl original, but finding a decent pair without selling my working kidney is probably unlikely.
Might have to order a pair of B4,s or similar.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20143 on: 20 April 2020, 14:39:34 »
Oh dear  :(
it's worth checking you haven't strained or disturbed a brake line too ,which can squirt brake fluid anywhere  :-\
I've never had a shock rust so bad that it leaks, i tend to swap for new @ 100K
but I've not had self leveling suspension since my C reg cav CDi  ;D
« Reply #20144 on: 20 April 2020, 14:48:38 »
Search interweb with the part number... You might get lucky :y
That said, at least you have plod springs on it, so the handling shouldn't suffer. Also Sachs OE shocks are readily available and arguably a better fit than the B4s. Although you may need to get the top mounts as well...  :y
Page created in 0.029 seconds with 20 queries.
