Author Topic: So what have you done to your car today?  (Read 8490566 times)
0 Members and 43 Guests are viewing this topic.
« Reply #20145 on: 20 April 2020, 15:18:34 »
Working days this weekend, so planning on doing the other donut bush Monday or Tues. if it stays dry.
Then need to start thinking about a service, plus cambelt, Aux. belt, remove sump to clean the strainer. It will never need working on again after Ive done that lot...……………………………
Shut up Stemo.
Should have kept my mouth shut. Fitted the other donut bush just now. Was a lot easier than the first and in a lot worse condition. The steel sleeve in the centre was completely detached from the rubber.
When I did the other side I did some cleaning up etc. around the various parts at the rear, including the annual ritual of removing surface rust from the  damper, and giving it a coat of paint, as I wanted to preserve the original self levellers.
When I finished fitting the bush today I noticed some oil on the drive at the other side of the car. Had a look and its running down the outer surface of the damper. Havent looked closely yet, but I think its likely that after cleaning it up this time, the metal has got too thin and its sprung a leak. Had to happen some time I suppose.
Shame, because I wanted to retain the self levelling and keep the old girl original, but finding a decent pair without selling my working kidney is probably unlikely.
Might have to order a pair of B4,s or similar.
 :-X :-X :-X
« Reply #20146 on: 20 April 2020, 15:20:05 »
Search interweb with the part number... You might get lucky :y
That said, at least you have plod springs on it, so the handling shouldn't suffer. Also Sachs OE shocks are readily available and arguably a better fit than the B4s. Although you may need to get the top mounts as well...  :y
Yeah, and it's not like you're decrepit or anything. You'll have them on in five minutes  ;D
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #20147 on: 20 April 2020, 16:12:25 »
Shut up STEMO.
Ive worked out what happened, I think. When driving the car down off the ramps the o/s ramp shot out from under the wheel so that side had the full weight of the car drop suddenly, which has probably burst the seal. Deffo not from the brakes as I checked that.
Will search for the part number and then trawl the interweb.
Any recommendations for Sachs OE dampers DG ? Had a quick look on ebay earlier but no further up to now.
Rear springs aren't plod btw. They are Sachs standard spec as opposed to Elite spec, so a little stiffer than it came out of the factory.
Migv6 le Frog Fan
« Reply #20149 on: 20 April 2020, 16:27:50 »
Was about to say, I think these might do the job. Lol.
https://www.ebay.co.uk/p/1416473504?iid=153195855972
Yours are slightly cheaper so will go for them unless I can find a decent pair of s/l for sensible money.
Correction, the ones in my link are a lot cheaper, and appear to be the same thing.
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #20150 on: 20 April 2020, 16:31:10 »
Opened the glovebox of the Range Rover looking for a business card.
« Reply #20151 on: 20 April 2020, 16:32:46 »
Can't argue with that price :y presume that you have just bought them :D
Migv6 le Frog Fan
« Reply #20152 on: 20 April 2020, 17:09:13 »
Not yet. Still attempting to find a pair of S/L, knowing its likely to be in vain. Will probably order them later today.
If the fittings from S/L shocks don't fit then I presume I need to go to VX and buy fitting kit for standard shocks ?
« Reply #20153 on: 20 April 2020, 19:43:30 »
Sachs ones should include the OE fittings. Bilsteins don't. :y
The ones you linked to had been sold by the time I looked at them...
Migv6 le Frog Fan
« Reply #20154 on: 20 April 2020, 20:55:35 »
Says 10 available at the moment ? Ive put a pair in my Ebay basket.
Might post a wanted ad for self levellers on here for 24 hours before ordering a pair of Sachs.
« Last Edit: 20 April 2020, 21:04:37 by Migv6 le Frog Fan »
« Reply #20155 on: 20 April 2020, 22:18:00 »
Get them bought... at that price they won't be around for long ;)
Migv6 le Frog Fan
« Reply #20156 on: 20 April 2020, 22:22:55 »
Have asked a question to make sure fitting kit is included. Will be a bit stuck if it isn't.
« Reply #20157 on: 21 April 2020, 09:54:57 »
All the Sachs ones I have fitted do ;)
Migv6 le Frog Fan
« Reply #20158 on: 21 April 2020, 12:44:10 »
Just ordered a pair. Just under £70 delivered which Im more than happy with. A bit sad that I had to bin the S/L, but I will keep everything in place in case I come across a pair of s/l shocks in the future.
456lbft
    • Omega MV6-Fred
« Reply #20159 on: 21 April 2020, 14:42:08 »
Got an MOT on the MV6, no advisories :y
Carlton 3.6 Track Car
Omega 3.2 MV6 Fred
