Author Topic: So what have you done to your car today?  (Read 7602324 times)
0 Members and 23 Guests are viewing this topic.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #20280 on: 02 May 2020, 22:05:30 »
Nice looking engine bay.
I could be tempted by this Merc (despite being silver) if it weren't for the lockdown thing. Plus I cant face getting rid of my Omega yet.
https://www.ebay.co.uk/itm/2000-MERCEDES-CL55-AMG-PRIVATE-PLATE-INCLUDED-NO-RESERVE/303555644245?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Well it is a V8 at Omega Money.
 You fancy becoming an Albanian drug dealer,  :)
Hoof'land storeman.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #20281 on: 02 May 2020, 22:34:03 »
If I did less than 10k miles /yr, something like that would be high on my list.  8)
« Reply #20282 on: 02 May 2020, 22:43:41 »
27 mpg from mine, will let you know what it does on a run when I get the opportunity  ::)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #20283 on: 03 May 2020, 00:31:15 »
My Omega does approx. 4000 per year and its replacement will do about the same. The plastic welsh hatchback does the commuting, nipping down the shops etc. at just over 60mpg.
Migv6 le Frog Fan
« Reply #20284 on: 03 May 2020, 00:37:19 »
Nice project, but a couple of notes...
On that model, they usually have ABC suspension, think Citroen SM. On speed. With a computer.
On that car specifically, the red display in the cluster is not good. Could simply be down to a 'dangle berries'ed battery, but the picture isn't clear enough to guess.
Also no MoT, but the ad is honest enough ;)
Otherwise, what could possibly go wrong :D
Im aware, and slightly scared about the ABC issues, although I believe that has its own dedicated " ABC fault, drive carefully" light.
I have even begun preparing for it on the off chance I end up buying one.
http://mercedes-abc-drive-carefully.blogspot.com/2014/08/overview-abc-system-isthe-key-part-of.html
Circa 360bhp would be fun though for that sort of money. If all else fails, bin the ABC and bung a set of coilovers on it.
« Last Edit: 03 May 2020, 00:43:03 by Migv6 le Frog Fan »
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #20285 on: 03 May 2020, 01:12:31 »
                     It’s not a real AMG though..
Laying a rubber road.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20286 on: 03 May 2020, 01:34:49 »
I forgot  ::) I filled up the Omega at a local garage the other day
less than a quid a litre  :)
also put air in the tyres and checked the rear suspension ,all good  :)
« Reply #20287 on: 03 May 2020, 09:19:59 »
That's a handy link :y
Also, occasionally, the dealer books crop up on ebay, not cheap, usually £100+, the Introduction to Service ones give alot of useful things like specs and system overviews, but the system specific ones are about as thick.
It's the leaks and component cost that put me off ABC, a valve body is £1,800, there's at least two.
Mine had/has (it's intermittent) an Airmatic fault. Turns out to be a sensor. Mounted in the engine bay and held in with two bolts... I will deal with it in due course.
The airmatic system can be replaced for about £1,200 as a worst case... 19 bolts, 12? air lines and four grub screws, so a solid day's work.
All that said the Coupe is a good looking car in the right colour... Looks stunning in a black cherry metallic, but like the Omega, you can generally get them in any colour you like, as long as it is Silver :D
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #20288 on: 03 May 2020, 12:18:33 »
When I had my E430 I averaged around 27mpg best was 30mpg which I thought was quite acceptable.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #20289 on: 03 May 2020, 16:36:11 »
Washed it. Hosed down, bucket of warm water and some Fairy Liquid, then hosed it again. Plenty good enough for a 12 year old Vectra.  ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20290 on: 03 May 2020, 17:14:05 »
name dropping snob  ;D
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #20291 on: 03 May 2020, 17:54:12 »
Ordered an oil filter for SWMBOS Subaru , was intending to take it in to the local trusted mechanic but decided on doing it myself, plenty of time at the moment.😎
ronnyd
« Reply #20292 on: 03 May 2020, 18:23:06 »
Couldn't get my normal Sainsbury stuff. Had to get the Fairy :o from Home Bargains.  ;D
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20293 on: 03 May 2020, 18:33:27 »
there you go again  ;D
« Reply #20294 on: 03 May 2020, 18:46:23 »
Yeh who does he think he is coming on here bragging that he shops at Home Bargains!  ::)  :P  ;D
Page created in 0.022 seconds with 20 queries.
