Author Topic: So what have you done to your car today?  (Read 7587212 times)
0 Members and 32 Guests are viewing this topic.
MikeDundee
  • Costa Del Peckham
« Reply #20295 on: 03 May 2020, 18:56:26 »
Cleaned out all the crud around the boot seals and replaced the boot struts, looking nice and clean now, crud free!!!!, Oh and put some LED bulbs in the speedo clocks, took off the old faded ABS sticker from the rear windsreen and put a nice new one in!!!
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #20296 on: 03 May 2020, 22:31:32 »
Washed it. Hosed down, bucket of warm water and some Fairy Liquid, then hosed it again. Plenty good enough for a 12 year old Vectra.  ;D
name dropping snob  ;D
Couldn't get my normal Sainsbury stuff. Had to get the Fairy :o from Home Bargains.  ;D
there you go again  ;D
Yeh who does he think he is coming on here bragging that he shops at Home Bargains!  ::)  :P  ;D
As you lot can see, i get to go to ALL the best places. Socially distancing of course.  :P
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20297 on: 03 May 2020, 22:39:20 »
Poundland ,Aldi ,Lidl, Morrisons ,Asda I can name drop too  ;D
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #20298 on: 03 May 2020, 22:51:20 »
Yes my cost of living shot up considerably when the 99p shop closed down and I had to start using Poundland ;D
  • Online Online
« Reply #20299 on: 03 May 2020, 22:52:30 »
You Northerners are so Bourgeois... :D
BazaJT
« Reply #20300 on: 03 May 2020, 22:54:21 »
Yes we're used to the finer things in life :D
« Reply #20301 on: 04 May 2020, 08:51:29 »
27 mpg from mine, will let you know what it does on a run when I get the opportunity  ::)
Come on, put some effort in.  I've been known to average only a couple of mpg more than that over a whole tank in the tractor pussy.
« Reply #20302 on: 04 May 2020, 08:53:26 »
The Omega had a whole day of a low charge rate yesterday.  Although it showed no symptoms, I think the charge level was quite low, as its doing <3m journeys currently.
Battlebus on the electricity today.  That's not moved an inch in the last 5 or 6 weeks :D
  • Online Online
« Reply #20303 on: 04 May 2020, 12:57:37 »
 ;D
I was seeing 25 on my commute...  :P For the week that it was working :-[
Not sure I could remember the way there now :-\
  • Online Online
« Reply #20304 on: 04 May 2020, 17:03:16 »
Nearside taillight had a crack in it, which was letting in water, screwing up the taillight bulb warning and flooding the nearside cubby when it rains.
Second hand are around £50 and new start around £100, but had a right result and found a pair of brand new, albeit aftermarket, facelift ones for under £100 which arrived today...
So two boxes ticked, upgraded rear lights and water leak cured.
« Reply #20305 on: 04 May 2020, 17:21:57 »
;D
I don't manage much more on my commute from a diesel, and its not like a drive fast due to traffic.  In fact, the speed is too slow to get any economy - most days before lockdown, I never got above 30mph ever, even though nearly half is a 60 limit, and nearly the other half is a 50.
Don't these pricks know if you get it between 45 and 55, that's a better sweet spot for economy, or just opps off out of the way, because life is too short to be stuck behind these self-abusers?
  • Online Online
« Reply #20306 on: 04 May 2020, 17:40:36 »
They key, I guess, is to keep the torque converter locked up, so perhaps manually select a lower gear to keep the rpm a smidge above lock up :-\
Obviously in the absence of being allowed to blow ditheres out of the way ::)
« Reply #20307 on: 04 May 2020, 17:50:48 »
even in lockup, its still too slow to be economical. And the speed is too eratic.  And sitting at junctions/roundabouts having to wait for rush hour to finish before they will pull out
  • Online Online
« Reply #20308 on: 04 May 2020, 17:54:01 »
True, I had overlooked the time/distance aspect ::)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #20309 on: 04 May 2020, 17:55:31 »
My commute has none of those things at the moment and its wonderful. Welsh hatchback claims to be doing 68mpg at the moment, and Im taking the Omega sometimes just for the pleasure of driving it on quiet roads.
Im sure it wont be too long before its all back to normal though, and the mpg  goes down with the blood pressure going up.
Page created in 0.024 seconds with 20 queries.
