Author Topic: So what have you done to your car today?  (Read 7841060 times)
0 Members and 48 Guests are viewing this topic.
« Reply #20325 on: 05 May 2020, 20:45:13 »
Doh... I blame Brexit. Or was it the Chinese? Or Matt Hancock? Or Donald and his disinfectant...  ::)
Pop the negative off if it's sitting. Check the key works the drivers door lock first though ;)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #20326 on: 05 May 2020, 22:24:12 »
Ive been using it for work occasionally so its not sitting for long periods. I had the headlights out to polish the lenses and when I refiited them I checked they were working ok. Then somehow thought I had switched them off, but stopped one click short and left the sidelights on.
What a dick !
« Reply #20327 on: 05 May 2020, 22:25:50 »
What a dick !
Been telling you that for years, Albs.  ;D
Migv6 le Frog Fan
« Reply #20328 on: 05 May 2020, 22:27:24 »
Far cough scouse git.
Tick Tock
  • Hereford
    • 2.5 V6 Facelift Estate
« Reply #20329 on: 06 May 2020, 14:38:18 »
Nice and sunny outside today and the wind has died down, so thought I'd tackle the exhaust heat shield stud that snapped off when I was doing the handbrake cable the other week. This is a critical one, as it holds the ends of the middle and last shield. Luckily it's on a cross strut box section, so ideal to drill, tap and fit a M5 screw.
Everyone likes a picture, so here's my progress.
The only other 2 which snapped off are midway, so they're well secured at either ends and jointly in the middle too. I'm going to leave these as they are because it's thinner gauge floor pan, and I don't want to risk drilling into anything like a wiring loom or anything which might be under the carpet inside.
Omega 2.5 V6 Facelift Estate.
Tick Tock
  • Hereford
« Reply #20330 on: 06 May 2020, 17:45:10 »
....... and over 2 hours just to replace the fuel filter. I'd bought some special pliers for the job, but seeing as this one had been on the car for 20 years, nothing was going to give. Astras and Corsas are easy because you can get to them, but GM decided in their wisdom to hide it up behind the diff on the Omega where you can't get to it.
After the disaster last time I changed an original one on another car, I didn't want to damage the pipe fittings this time, and it's almost impossible to get a screwdriver behind those tabs as well as a second hand in there.
The swear jar is overflowing again  :-[ but at least the job's done.
Keith ABS
  • Maldon Essex
« Reply #20331 on: 06 May 2020, 19:12:17 »
 Used the Monaro for work
Funny how the journey didnt take as long
antanasg12345
  • United Kingdom
    • Audi
« Reply #20332 on: 07 May 2020, 11:52:21 »
Finally I was able to fix my steering wheel. It kept on locking randomly whenever I steer it.
« Reply #20333 on: 07 May 2020, 12:04:14 »
Do the indicators work? The switch will sieze up if you don't use them, which is probably what's causing the steering wheel to jam.
« Last Edit: 07 May 2020, 12:05:59 by Doctor Gollum »
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #20334 on: 07 May 2020, 13:59:49 »
.      Whenever? Don’t you steer all the time then?
Laying a rubber road.
    • 530D M Sport, 330i Coupe
« Reply #20335 on: 07 May 2020, 15:24:16 »
I finally bought the correct tool for this job last year...
https://ebay.us/JnzvDL
....after years of pissing around with cheapo Sealey tools and screwdrivers.
I also found that on the saloon it can help to take the pipe off the tank top plate and drop it down so you can lower the whole lot down.
MikeDundee
  • Costa Del Peckham
« Reply #20336 on: 07 May 2020, 16:33:57 »
Well after finding some holes in the passenger wheel arch, went onto clean the engine bay, long overdue, and had ordered a heel mat for the car mats that I have had sitting around for quite some time as the old ones had a lot of heavy footed holes in the drivers one, so they have been binned. Could'nt get the right colour of heel plate so sprayed and coated, pics below....
Before...
After.....
Heel Pad for the car mat...
« Reply #20337 on: 07 May 2020, 20:14:16 »
Over the last couple of days, discs and pads all round. Discs were original, and the pads have been changed previously, about a decade ago from the way the discs were welded to the hub flanges ::) handbrake mechanism was all free and in good order and looks to be factory judging by the paint spots on the retaining springs. Just needs a final tweak, so that'll get done next week...
Discovered that the rear brake hoses are perished ::) so ordered front and rears...
Then went to change the OSF rear lower arm ball joint, and quickly discovered that in order to do so the front lower arm needs removing as it's in the way. Everything, including the abs sensor 8), came apart easily... Except the front lower arm to hub ball joint. Could I get that apart? Could I fek, ended up throwing it back together. Didn't even pretend to look at the near side one :-X
Inner bushes are also a bit ropey, so set of front arms is in the offing. But there's a catch. The front struts attach to a ball joint on the lower arm... With a pair of 5mm grub screws. ;D
Lots of plus gas, a couple of spare hex bits and a handful of lucky pills before I even think about starting that job...
On a positive note, the last MoT had an advisory for rear shocks damaged both sides.
All four struts are tidy, dry and perfectly serviceable, if a little aged, more importantly, the Airmatic works.
Two steps forward, two steps back and all that.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #20338 on: 07 May 2020, 20:48:35 »
Had front tyres replaced. £150 so ok with that. Nexens.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #20339 on: 08 May 2020, 17:04:55 »
You need some heat.   A plumbers Torch might do, takes time to get it red tho.
Hoof'land storeman.
Page created in 0.03 seconds with 20 queries.
