Author Topic: So what have you done to your car today?  (Read 7601747 times)
0 Members and 39 Guests are viewing this topic.
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #20535 on: 24 June 2020, 16:04:34 »
Astra on rubbish tip duty
« Reply #20536 on: 24 June 2020, 18:15:55 »
If it wasn't for my strong willpower, I would have washed to cars today 8)
;D
Your determination has inspired me not to wash mine.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20537 on: 24 June 2020, 18:19:09 »
;D
I'm doing my part too ,saving water  ;D
« Reply #20538 on: 24 June 2020, 21:09:32 »
I sat in the drivers seat while a big roller went over the top and back.
« Reply #20539 on: 24 June 2020, 21:36:27 »
That's 10 Romanian slaves that won't get tea tonight...  :D
« Reply #20540 on: 25 June 2020, 17:09:07 »
I do that with the battlebus. Mainly because its had a fair record on breaking BP's carwash when the aerial gets tangled.  It usually gets most of the mould off first though :)
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #20541 on: 28 June 2020, 19:48:16 »
Re-attached the CV boot in its proper place. Breaking the poxy pair of CV boot clip pliers that Amazon delivered barely 4hrs ago in the process.
That suits me just fine as I'll get a refund and can buy a decent pair at my leisure, meanwhile the sh!troen is back in business.  :y
« Reply #20542 on: 28 June 2020, 19:56:42 »
TB, you should be ashamed of yourself.
We all expect scousers to be bone idle but you are from Brackley. :)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #20543 on: 01 July 2020, 19:14:16 »
Today -
cleaned the breathers.
fitted new pollen filter.
Drained coolant, gave it a flush, then filled with new longlife coolant.
Drained the oil and fitted a new oil filter.
Removed the sump....................then torrential rain stopped play.
Tomorrow hoping to -
clean the oil strainer
clean out and refit the sump
fill with fresh oil
fit new air filter, if it arrives.
That will leave the cambelt kit and aux. belt to fit.
« Reply #20544 on: 01 July 2020, 19:17:08 »
Acquired a new rear bumper to replace the battered and bruised one that came with the car.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #20545 on: 01 July 2020, 19:44:20 »
Broke it  :(
screen wash jets not working
so I had a fiddle ,got those working but the headlamp wash pump is definitely cream crackered  (tested the pump direct to 12v)
windscreen jet wash pump seems to be weeping slightly from the bearing hole , so that needs replacing too
and I have had Insignia mist screen wash jets sitting on my desk for a few weeks ,
so when the pumps come i may as well flush the pipework and fit those too
opted for Saab 90508709 pump at £17 clicky because the Vauxhall one in a Saab box clicky is £23  ;D
forgot to look which terminal configuration the screen wash pump is ,so back out to look  :-[
this one £5.46   :)
« Last Edit: 01 July 2020, 20:01:46 by dave the builder »
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #20546 on: 01 July 2020, 20:56:03 »
Washed it 8), Then it pissed down,  >:( Bugger. ;D
Migv6 le Frog Fan
« Reply #20547 on: 02 July 2020, 20:10:11 »
Today -
fill with fresh oil
Today almost went according to plan, apart from the air filter didnt turn up.
Anyway, cleaned out the sump as it was off.
removed the oil strainer (a bit of a faf) and blasted some carb cleaner down it. Then notice something jammed inside it.
Got a pair of tweezers and teased it out.
A lump of folded up plastic ! God knows how or when it got in there, but it was before my time.
Then refitted the strainer, smeared sump and block faces with Hylomar blue and refitted it. Refilled with fresh 10/40 semi and started it up. Burped the cooling system and topped it up. Job Jobbed.
« Reply #20548 on: 02 July 2020, 20:14:06 »
Probably a lump of camcover gasket :D
Migv6 le Frog Fan
« Reply #20549 on: 02 July 2020, 20:18:01 »
Nope, definitely apiece of stiff black plastic.  :-\
Page created in 0.184 seconds with 20 queries.
