Author Topic: So what have you done to your car today?  (Read 6907878 times)
0 Members and 30 Guests are viewing this topic.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #20760 on: 12 August 2020, 08:59:03 »
ESP : C111200; C327100: C326600
C is chassis. 1112 is the major fault code 02 is the minor. In this instance 1112 refers to a bad front ABS sensor.
So a quick lesson in DTCs, the first four digits are the circuit identifier, the last two, the condition identifier.
C1112 is the front left wheel speed sensor according to my info.
the 02 is an implausible signal.
That tells me that electrically all is ok (not open circuit, short circuit, short to batt) so there is a either an issues with the reluctance ring or a load of crudd affecting the signal.
Am I misreading something, as the codes posted show minor/condition code is 00 ?
No, you are correct, from what I've read up about it, it's a fairly common fault on my model, new sensor should cure it.
Worst case scenario, it could be the Reluctor ring which is a lot cheaper, but a bit of a pig to change.
I like red cars
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #20761 on: 13 August 2020, 07:29:44 »
Try 22Nm ;)
Where did you get that from, the correct torque setting is 7Nm.
I like red cars
« Reply #20762 on: 13 August 2020, 10:01:26 »
Haynes, albeit an earlier model, hence use of the word try...
7nm is practically finger tight :-\
Was it not given in the guide I linked to?
« Last Edit: 13 August 2020, 10:05:56 by Doctor Gollum »
« Reply #20763 on: 13 August 2020, 11:06:49 »
Try 22Nm ;)
Actually WIS doesn't give a torque specification...
https://photos.app.goo.gl/zz2PGRse5rRqzwDP6
Snippets from Document AR42. 30-P-0712CW ;)
For the purposes of the exercise, I presumed your car to be WDD204203....... C250CDI BlueEFFICIENCY T-Modell, C250 ;)
« Last Edit: 13 August 2020, 11:18:00 by Doctor Gollum »
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #20764 on: 13 August 2020, 14:53:11 »
Try 22Nm ;)
It's a 220, sensor fitted, jobs a good'un. It's impossible to get a torque wrench on the bolt anyway, so the torque setting is irrelevant ;D
I like red cars
« Reply #20765 on: 13 August 2020, 15:24:41 »
Without plugging it in, you'd struggle to tell the difference  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #20766 on: 13 August 2020, 16:27:14 »
Try 22Nm ;)
why would a sensor need a TTY bolt? And 7Nm suggests an M6 bolt, so the difference between yielding and snapped-off-flush-in-the-hole is tiny.
Just answered my question: it's a Mercedes - pointless, complicated, fussy engineering for the sake off it.
456lbft
    • Omega MV6-Fred
« Reply #20767 on: 13 August 2020, 16:37:48 »
Not today, but late last night, V6 exhaust mocking up on the parts car, then the engine is coming out.
It will be interesting to compare sounds and performance between conventional and X-pipe versions.
Carlton 3.6 Track Car
Omega 3.2 MV6 Fred
« Reply #20768 on: 13 August 2020, 18:56:25 »
Put the Pussy's door back together, only to find the bass speaker is muffled and the other is dead. So strip it down again, and can see the bass is damaged by the original poor build, as the loom was trapped between the speaker and the doorcard, and has split the flexible ring that holds cone to frame.  Top speaker just dead.
So swapped with speakers the other side, and the faults moved with the speakers.
Also found on the good door, poor build quality meant the loom was pressed against a sharp self tapper.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #20769 on: 13 August 2020, 23:53:51 »
Thats pretty shit given the cost of the car when new :-\
other rides
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #20770 on: 14 August 2020, 09:33:31 »
I learned a valuable lesson yesterday, I'm too old to mess about with cars. :'(
If my next door neighbour hadn't come to my rescue, the car would still be in bits today.
Changing the front wheel sensor was far more complicated than Haynes suggested, in fact they got a number of things wrong.
I like red cars
« Reply #20771 on: 14 August 2020, 09:53:36 »
It's only 8 steps ???
The only difference that I can see between the Pelican Parts guide and WIS is that WIS mentions replacing the sealing ring onto the new sensor (if not supplied with one) in order to prevent water from getting to the wheel bearing.
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #20772 on: 14 August 2020, 11:55:19 »
First off, both suggest there are 3 bolts holding the wheel arch cover, there are 7, 4 located underneath the car + 4 heavily concealed push in connectors.
The only way to remove the sensor from the back of the hub and get at the bolt that is holding it is to remove the dirty great clip (a nightmare) holding the cables and brake pipe from the arm.
I can't crawl underneath cars anymore, if I had known I had to I wouldn't have started the job
I like red cars
« Reply #20773 on: 14 August 2020, 12:05:40 »
That's all covered in the link I shared...
« Reply #20774 on: 14 August 2020, 13:40:00 »
https://www.pelicanparts.com/techarticles/Mercedes-W204/62-BODY-Wheel_Well_Liner_Removal/62-BODY-Wheel_Well_Liner_Removal.htm :-X
Linked from the original link as part of the instructions...
And first thing on the list "Begin by safely lifting and supporting the vehicle and remove the wheel from the area you are working in."
Never too old to read the instructions...  ;)
« Last Edit: 14 August 2020, 13:41:54 by Doctor Gollum »
Page created in 0.022 seconds with 20 queries.
