Migv6 le Frog Fan
Just got home. Pulled the handbrake up, heard a clunk and then it seemed to lose all resistance. Probably a broken cable, r something pulled through the backplate.
Oh well another job to do for the MOT.  ::)
Quote from: Migv6 le Frog Fan on 20 November 2020, 15:56:50
The cable outer ends pull through the 'clamp' they sit in because both bits are rusty. Adjusting the handbrake so it actually does something exacerbates this.
A new cable isn't expensive, nor is it hard to fit if you're not worried about putting the exhaust heat shields back.
DAMHIK ;D
Quote from: Nick W on 20 November 2020, 16:15:53
DAMHIK ;D
Translation:  Don't Ask Me How I Know   ::)  :)
Quote from: Sir Tigger QC on 20 November 2020, 18:03:59
DAMHIK ;D
We knew that already  :P
Diesel till I die
ronnyd
Quote from: STEMO on 20 November 2020, 18:37:13
DAMHIK ;D
I had to Google it. :-[ I've had a sheltered (social media) life you know.  ;D
Quote from: ronnyd on 20 November 2020, 19:05:55
DAMHIK ;D
Me too Ronny and Uncle STEMO didn't have a scoobies either.  ::)   He just makes out he knows stuff!  ;D
ronnyd
Quote from: Sir Tigger QC on 20 November 2020, 20:50:45
DAMHIK ;D
;D ;D ;D ;D :y
Viral_Jim
Quote from: Marks DTM Calib on 20 November 2020, 09:00:43
Quote from: Viral_Jim on 19 November 2020, 22:06:28
Quote from: Marks DTM Calib on 19 November 2020, 12:12:15
Totally new infotainment system (PIVI as launched on Defender - much slicker and faster) with full system Software over the air, new amps, speakers, telematics, ADAS (surround cams are standard) etc.
Some software tweaks to the drive train to increase range a little, better charging options (now supports three phase type 2 7kW charger support added)
A 'work perk' with salary sacrifice making it very affordable on a three year deal  :y
Nice! I've not heard anything about the new infotainment on the defender, but given the positive news the last installation got, it should be excellent.
3 phase charging is good, but what's the need if it's limited to 7kw? Or is it primarily aimed at other markets that runnkess than 230v?
Up to 7kw is single phase, 22kw+ on three phase which is much sought after in Europe and quite common as a public faster charger solution  :y
Ahh I see now. Yes, seen plenty of those on the continent.
Also I'd wished for it a few times on the e-golf when using the w@nky ecotricity chargers as the type 2 was very often the only port working  ::)
Shackeng
Sold the 3.2 Elite, very sad to see it go :(, but due to circumstances it was just not getting used. New owner is a forum member, and I am sure will enjoy it.
Got the level correct in the autobox on the project after replacing one of the cooler pipes.  :)
Washed Mrs VXL's Astra so that should pass the MOT now  ;D
dave the builder
 ;D
don't forget to sanitize the inside bits of the Astra AFTER the MOT test
Apparently there's a virus doing the rounds  ::)
ronnyd
Quote from: dave the builder on 22 November 2020, 16:25:49
;D
Blimey, didn't know nothin 'bout that. :o  ;)
Insured it.
Then wiped a whole load of water off the inside of the windscreen.
Rangie
Lovely day here so just had to wash the Range Rover again..😄
