Author Topic: So what have you done to your car today?  (Read 7479854 times)
0 Members and 56 Guests are viewing this topic.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #21615 on: 04 January 2021, 21:15:46 »
I've got one of them new fangled wrist clocks  8)
but the clock on the Omega keeps much better time than I do anyway  ;D
...... MOT is 2 or 3 weeks....   ...although now hoping that it will et an MOT extension until the summer.
it won't get an MOT extension
test centers are open ,it's only tier 5 ,not a real lockdown  :P
« Reply #21616 on: 04 January 2021, 21:41:47 »
FWIW, my satnag is fine.
Have you ever tried it in Cornwall?
Mine only seems to use roads with grass growing up the middle. >:(
« Reply #21617 on: 05 January 2021, 07:56:30 »
Discovered that, on a MY2017 car:
It has incandescent bulbs in the rear light clusters.
If one of the brake light bulbs fails, there's no bulb failure indication.
There are 2 brake light bulbs in each cluster, though, so no drama, surely?
.. Except that it disables the working one when it detects that the other one has failed. ::)
Filed under "words fail me". >:(
Mind you, they couldn't make the clock work properly either, or the sat nav. ::)
Clock is easily sorted with a BCM software update........as for bulb failure, its a discussion I have had with the BCM team a few times. I know the system has a stabilised supply to the lights (not the usual direct battery feed) and the 'view' was that the bulbs would last for many many years.......but of course they don't.
The other bulb should only be disabled if the first one fails such that it causes a short.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #21618 on: 05 January 2021, 10:15:21 »
Thats most of them down here :y
other rides
« Reply #21619 on: 05 January 2021, 17:41:46 »
Yes I heard they let the A30 go a bit!  ;D
« Reply #21620 on: 05 January 2021, 19:54:42 »
I have, and it was fine.  Better than me as it happens, as I chose to ignore it in Port Isaac, and ended up with less than a rizla between the rear wheel ache and a stone wall one side, and some scaffolding the other.
But mine is the older system, prone to butt frukkin' itself during map updates.  Fortunately, I worked out how to manually copy the map onto the drive, though it means removing the hard drive from the IAM.
As from green grass up the road, I drive for miles looking for those sorts of roads ;D
    • 530D M Sport, 330i Coupe
« Reply #21621 on: 05 January 2021, 21:51:23 »
Green grass in the middle of the road is perfect for cleaning the sump pan on an Omega, assuming you're running the correct springs!
« Reply #21622 on: 05 January 2021, 23:35:11 »
It was odd behaviour. The remaining bulb would light as you start it, then extinguish and stay off until the next start. I checked both bulbs with a multimeter and the faulty one was completely O/C by the time I'd got it out of the car. It may have shorted at some point but not badly enough that the other one didn't light although I can see why it might shut down the circuit in that case to protect other loads on the regulated bus.
Drewomega
  • Aviemore and Mallorca
    • SKODA Octavia Scout 2.0
« Reply #21623 on: 09 January 2021, 11:24:16 »
Well! the old bus passed its MOT yesterday after a full 9 months sitting in the steam railway car park. Had to park it there because of flooding problems where I live. I have had one Omega written off already. I drove to the MOT station with the brakes on most of the way to clear the discs! Good result though.  :y :y
I'm always last in the office in the morning but I make up for it by leaving first.
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #21624 on: 09 January 2021, 11:58:38 »
Congratulations on the MOT pass  :)
best get using it now , they don't like  long rests  ;D
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #21625 on: 09 January 2021, 12:18:00 »
Booked SWMBOS Subaru in for its MOT .
New POD
  • Miseryside
    • NEED MV6
« Reply #21626 on: 09 January 2021, 15:36:14 »
Today I parked on the flat. One rear wheel on frozen mud, and the other on sheet ice.
The traction control does not work in those circumstances.
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #21627 on: 09 January 2021, 15:45:08 »
The traction control does the tyres do not work in those circumstances.
FTFY :y
New POD
  • Miseryside
    • NEED MV6
« Reply #21628 on: 09 January 2021, 22:40:41 »
FTFY :y
Thanks. You are correct.
iansoutham
  • SE London
    • Omega 2.0 m/f/l est CDX
« Reply #21629 on: 10 January 2021, 17:00:51 »
Update on mine....
After making a makeshift shim to slide the seal on with, managed to get that to hold oil.
Top mounts changed and bump stops changed as well (main reason for mounts as damper boots were sitting on the shock body. Done all that to find the alternator is over hanging to 17A+ so that is also goosed.
Found another one in my collection which will be tried tomorrow. If not, new one coming.
Then, once that done, all codes to be cleared and then taken into work one evening to get re-geometried.
