Author Topic: So what have you done to your car today?  (Read 6899103 times)
0 Members and 61 Guests are viewing this topic.
    • Grandland 1.5 diesel
« Reply #21855 on: 17 February 2021, 18:06:37 »
I put mine through an up and over this morning, but I did have to queue for 20 minutes.
Diesel till I die
« Reply #21856 on: 17 February 2021, 18:08:18 »
JLR warn not to do that.
An Indian car built by brummies. Hmmm, I see their point ;D
« Reply #21857 on: 17 February 2021, 18:10:26 »
These new fangled contraptions haven't made it to my part of Darzetzhire yet.  :-\  ::)
Nor over the borders in Debenzhere or Zummerzet either...  :D
« Reply #21858 on: 17 February 2021, 18:12:02 »
They're ace. Wash, rinse, wax, dry and wheels half washed for £3.80  ;D
Diesel till I die
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #21859 on: 17 February 2021, 22:31:58 »
If you're really lucky you might even get some of the sides done too.  ;)
« Reply #21860 on: 23 February 2021, 18:22:14 »
Removed all personal possessions from TBE  :'(, then drove it to the chippie, and remembered what a good car the Omega is.
« Reply #21861 on: 23 February 2021, 18:54:44 »
You'll miss it, but if you don't want to fix it, then it's time to let it go ;)
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #21862 on: 23 February 2021, 19:06:04 »
Still trying to get the turbo off the C lio. One of the four 10mm nuts that joins the cat to the turbo is rounded, and of course its th one that you cant even see, and can only work on by feel.
Stuck now not sure what to do. Might just get the lump hammer and chisel out tomorrow and lose my temper with it and see what happens.
Sick and tired of the bloody thing now.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #21863 on: 23 February 2021, 19:08:31 »
You’re not going to do that job twice :y
Laying a rubber road.
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #21864 on: 23 February 2021, 19:15:04 »
Cut two dampers off the newly arrived Civic. Well known for seizing solid, the first one took me a while, the second one I showed no mercy.  Satisfying.
Raeturbo
  • South Wales
« Reply #21865 on: 23 February 2021, 19:59:38 »
Never show mercy, Tora tora tora!
Migv6 le Frog Fan
« Reply #21866 on: 23 February 2021, 20:10:45 »
Not even sure I will get it finished once at this point. A second time would definitely be either a box of matches or over a cliff.
« Reply #21867 on: 23 February 2021, 20:12:59 »
Part ex it for another diesel 190 whilst you still can ;)
cam.in.head
  • West yorkshire
    • omega cdx 2.6 auto
« Reply #21868 on: 23 February 2021, 20:18:27 »
after having some paintwork done. rectified some minor issues found on return.
number plates refitted straight !
rear bumper bottom fittings refitted
under headlight trim refitted straight
badges refitted
some overspray removed on inner arch plastics
also but not garages fault
shimmed both front check straps bushes to solve cracking noise
replaced rear indicator bulbs which were not very orange
changed aux belt for non aircon one
resoldered rear door speaker cone leads on one side
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #21869 on: 23 February 2021, 21:31:49 »
Do you know anyone with an Irwin (Bolt Remover) Socket Set that you could borrow. They are designed to bite in to mullered bolt heads when undoing. If it's a stud and nut you'd have to make sure the socket was deep enough.  :y
Page created in 0.025 seconds with 20 queries.
