Author Topic: So what have you done to your car today?  (Read 7457241 times)
0 Members and 58 Guests are viewing this topic.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #21870 on: 23 February 2021, 23:02:56 »
10mm, I would have thought you could either remove or shear it off with a pair of mole grips? Presumably with the turbo off the car access/fixing it won't be too tricky.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #21871 on: 23 February 2021, 23:19:40 »
Probably have to take it off with the cat as the bolts can be almost impossible to get at properly.
Laying a rubber road.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #21872 on: 23 February 2021, 23:45:35 »
Not really enough space to get mole grips on and be able to twist them around to shear it.
Cant take the cat and turbo off together, as not enough space.
Dont know anyone with Irwin sockets, so might have to buy one and wait for delivery before going any further.
May try and get a junior hacksaw in there tomorrow. If there is space it will be time consuming but I can liv with that if it does the job.
Bloody French !  ::)
I really want to start playing around with the Boxster, but need to get this done first if I can. :(
« Reply #21873 on: 24 February 2021, 00:19:24 »
Undo the engine mounts and lever the engine away from the turbo enough to drop the turbo and cat out :-\
Raeturbo
  • South Wales
« Reply #21874 on: 24 February 2021, 01:26:44 »
                    Yes I think you’ll get it out that way with a bit of luck
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #21875 on: 24 February 2021, 07:42:33 »
Looked in the garage to make sure it is still there.  :-\
    • Grandland 1.5 diesel
« Reply #21876 on: 24 February 2021, 07:49:45 »
And is it? Don't keep us in suspense  ;D
Diesel till I die
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #21877 on: 24 February 2021, 08:49:16 »
You’re not going to do that job twice :y
Not even sure I will get it finished once at this point. A second time would definitely be either a box of matches or over a cliff.
It's all easy practice for when you start on the Porsche. Another thing to do is find all your parts receipts, and triple the prices....
Migv6 le Frog Fan
« Reply #21878 on: 24 February 2021, 14:52:46 »
Got it off at last. Welded a bigger nut on the end of the stud and managed to unwind it. Also got the intercooler out, which had quite a bit of oil in it, as expected.
Back to work tonight for a couple of nights, then start cleaning everything up and put it back together.
Not looking forward to it, but needs must.  ::)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #21879 on: 24 February 2021, 17:50:01 »
Excellent job :y
« Reply #21880 on: 24 February 2021, 17:50:46 »
With no small amount of swesring, got the Civic's suspension and brakes all fitted. In between the sort of rainstorm that would have Noah breaking out his Workmate...
Raeturbo
  • South Wales
« Reply #21881 on: 24 February 2021, 20:45:51 »
[/quote
               Obviously don’t forget to check oil supply and drain are clear and not gunged up :y
Migv6 le Frog Fan
« Reply #21882 on: 24 February 2021, 21:55:53 »
Yep, going to clean out everything I took off before it goes back on.  :y
« Reply #21883 on: 24 February 2021, 22:06:11 »
You love little Pierre.  :-*
Diesel till I die
Migv6 le Frog Fan
« Reply #21884 on: 24 February 2021, 23:47:59 »
It has been a useful little contraption for commuting as I get over 60mpg from it.
It has really tried my patience recently though. One more episode like this one and the swan vestas are coming out.
Page created in 0.029 seconds with 21 queries.
