Author Topic: So what have you done to your car today?  (Read 6921048 times)
0 Members and 17 Guests are viewing this topic.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #22305 on: 27 May 2021, 17:18:06 »
May help?
They can be replaced. It'll be a matter of taking the headlamp unit off, heating it gently and prising it apart and replacing the part. I suspect it won't even be the LED itself, it'll be a solder joint which will have been heated and come apart either on the LED itself or a PCB it's fitted to.
Obviously a main dealer won't go anywhere this sort of thing and can only quote on a replacement unit. I'd be pushing for them to sort this out.
Ive had same problem ,but i took it apart and went over the pc board and found a dry joint near the 6 pin led conector , soldered it up and now the indicator works fine , so 2p of solder an some elbow grease saved me alot of money
Reply
Dodgy
Dodgy
Registered
Joined 4 mo ago · 2 Posts
#43 · 4 mo ago
Hi , am new , had same problem with front indicator so i took it apart , and found were the 6 pin plug goes to the circuit board there were a couple of dry joints on the micro resistors , i resoldered them and evrything is back working so for 2p of solder and a bit of elbow grease saved me money, just got to reseal the headlight cover and put it back in the car witch takes longer to do than to fix it
Laying a rubber road.
Raeturbo
  • South Wales
« Reply #22306 on: 27 May 2021, 17:18:56 »
I took this from a forum :y
    • Grandland 1.5 diesel
« Reply #22307 on: 27 May 2021, 17:35:52 »
Sounds the kind of job Jaime would be up for, and very capable of doing  :y
And pity the jag forumites if it works  ;D
« Last Edit: 27 May 2021, 17:39:11 by STEMO »
Diesel till I die
Diesel till I die
« Reply #22309 on: 27 May 2021, 17:59:14 »
Indeed, if drying it out doesn't work, I will be pulling it apart.
Due to the ball ache removing the headlight, if I could get one for £200-£300, I'd buy one and fit it, and repair the old one.
« Reply #22310 on: 27 May 2021, 18:01:06 »
And my current thought is there might be a small driver inside low down, that has got wet.
Although there might not be a driver in the lamp, as the CJB defo has output drivers.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #22311 on: 27 May 2021, 18:02:15 »
I knew you should have bought an E class ::)
I like red cars
« Reply #22312 on: 27 May 2021, 18:03:36 »
//TB checks if he still has a hole up his arse.
It appears I do, so not getting an E class yet.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #22313 on: 27 May 2021, 18:04:39 »
Drove to work with the top down, Bob Seger on the stereo, and the wind on my *hair.
* Both of them   ;D
« Reply #22314 on: 27 May 2021, 18:14:06 »
* Both of them   ;D
Did you forget your pants?  :D
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #22315 on: 27 May 2021, 18:19:03 »
* Both of them   ;D
Presumably you are now saving all your pennies to buy a proper Porsche? :)
« Reply #22316 on: 27 May 2021, 18:21:32 »
* Both of them   ;D
935 or a 962?
  • Chatham, Kent
« Reply #22317 on: 27 May 2021, 18:49:41 »
* Both of them   ;D
935 or a 962?
Beetle
« Reply #22318 on: 27 May 2021, 21:45:09 »
* Both of them   ;D
935 or a 962?
Beetle
In which case I would probably keep the Boxter ;D
    • 530D M Sport, 330i Coupe
« Reply #22319 on: 28 May 2021, 14:39:56 »
Started refurbishing some standard calipers ready to remove the 6 Pot Brembo's and associated bits of the Silver car.
